My first table
Forum topic by Rockytop posted 02-22-2017 02:42 AM 759 views 0 times favorited 6 replies Add to Favorites Watch
View Rockytop's profile
Rockytop
37 posts in 532 days
02-22-2017 02:42 AM
So this is my first table! Probably a little over my head with the tools I have, but I’m quite proud of it.
It’s a farm style table out of the barnwood from the barn I tore down last year. Feel free to expand the picture. I’d love to hear what I could’ve done better. Just no rude comments. I’ll share steps of the build after some comments
View bondogaposis's profile
bondogaposis
4611 posts in 2259 days
#1 posted 02-22-2017 03:02 AM
How is the table going to be used? The lower stretchers seem odd, only on 2 sides, do you need them at all? How is the top attached?
-- Bondo Gaposis
Rockytop
#2 posted 02-22-2017 03:10 AM
- bondogaposis
It’s a kitchen table for a local lady. The top is attached to the frame by pocket holes & also used pocket holes to make the top
View canadianchips's profile
canadianchips
2600 posts in 2904 days
#3 posted 02-22-2017 03:59 AM
I like it.
You left the worm holes.
You left the knots.
These all add great character to it.
Very Nice job.
“If it were mine” I would try to add saw mark swirls in top, like a rough sawn look.
View clin's profile
clin
798 posts in 903 days
#4 posted 02-22-2017 04:14 AM
It looks good. I really like the character of the wood and the look of the finish.
All your pics are from the stretcher sides. I assume there is an apron on the other sides not shown. I see that the stretchers are attached with pocket screws. How are the aprons attached to the legs?
Given the apparent size of these joints, I would agree with Bondo that perhaps the stretchers aren’t needed, but they don’t hurt.
If the leg to apron joints were traditional mortise and tenon, then I’m sure a stretcher isn’t needed. But, I’m assuming they are are butt joints with pocket screws. If so, it will likely work well for a long time, but won’t ultimately hold up like an M&T joint would. Those pocket screws may need tightening if the wood dries out.
Since you got the wood from a barn, I assume you have a lot more of it. That wood has a lot of character, and if you didn’t this time, consider M&T joints on the next project. With M&T you’d have something that will last generations.
Regardless of the details, it looks great.
-- Clin
View Aj2's profile
Aj2
1272 posts in 1705 days
#5 posted 02-22-2017 05:19 AM
Rustic lots of character what’s not to like.
Good first
Aj
-- Aj
Rockytop
#6 posted 02-22-2017 02:23 PM
Given the apparent size of these joints, I would agree with Bondo that perhaps the stretchers aren t needed, but they don t hurt.
If the leg to apron joints were traditional mortise and tenon, then I m sure a stretcher isn t needed. But, I m assuming they are are butt joints with pocket screws. If so, it will likely work well for a long time, but won t ultimately hold up like an M&T joint would. Those pocket screws may need tightening if the wood dries out.
Since you got the wood from a barn, I assume you have a lot more of it. That wood has a lot of character, and if you didn t this time, consider M&T joints on the next project. With M&T you d have something that will last generations.
- clin
Clin, you are correct. All connections are pocket holes. According to cheap hf moisture meter my lumber was around 6%. I know it’s a little dry, but I tried to get it up some with no real change. My shop isn’t climate controlled so it’s a little difficult.
