Spiraled Elm - Is it even remotely stable?
Forum topic by Jeff_in_LSMO posted 02-21-2017 08:24 PM 1615 views 0 times favorited 4 replies Add to Favorites Watch
View Jeff_in_LSMO's profile
Jeff_in_LSMO
352 posts in 2489 days
02-21-2017 08:24 PM
Topic tags/keywords: elm twist twisted spiral slab
So my father-in-law pulled aside a large elm log from a job site and asked if I wanted to mill it up. It wasn’t necessarily the most beautiful log, and I could see a fairly severe twist/spiral from some of the exposed wood, but I thought it would be an interesting experiment.
I went about making some slabs. Immediately I started having problems as the slabs pulled on the saw. The wood was gorgeous, however, so I kept going. Several slabs later, I stacked them in the loft in the barn. I was crossing my fingers that the loft wouldn’t get too hot and there wasn’t too much stress in the boards, but, I was wrong. A good experiment it was.
Several of the slabs twisted or cupped quite a bit and / or had major checks. Two of them almost completely shattered.
Not being one to just throw it all out, can any of it be salvaged?
If I planed them down flat (flatter is more realistic), would they be remotely stable?
What if I cut them into small pieces, would I just have problem after problem.?
Should I just turn them into abstract art?
View chrisstef's profile
chrisstef
17683 posts in 3155 days
#1 posted 02-21-2017 09:37 PM
Do you have any idea as to what the current moisture content is? I would venture to guess that once its hit 7-10% it might be done moving around, until you mill it that is. Id give it a shot and see what happens.
Jeff_in_LSMO
#2 posted 02-21-2017 10:15 PM
around 14-15% right now. what about seasonal movement? on spiral grain is there a rule of thumb or something i could use? basically, i don’t want to go through the trouble of turning them into something if that something is all askew in a season.
i moved it to my basement, which is actually pretty well controlled for humidity. i’ll give them another couple months and then clean them up a bit, then let them sit some more and see what happens. I should turn this into a blog post / experiment.
View Lazyman's profile
Lazyman
2528 posts in 1536 days
#3 posted 02-21-2017 11:13 PM
I would love to see some pictures of the grain.
View Monte Pittman's profile
Monte Pittman
29879 posts in 2487 days
#4 posted 02-21-2017 11:27 PM
I use a lot of elm. I love it and have had good results.
