Can You drill any steel??
Forum topic by heldercruz100 posted 02-21-2017 07:32 PM 1499 views 0 times favorited 28 replies Add to Favorites Watch
View heldercruz100's profile
heldercruz100
44 posts in 535 days
02-21-2017 07:32 PM
Topic tags/keywords: steel problems how to tips ideias
For a while ive been trying new projects and ideias and in a few of them its required to drill steel. However when I try to drill nothing hapens and after a while the tip is ruined, has this hapened to anyone?? I ve been using carbon steel, and bought from a hardware shop, I doubt it has been heat treated…
-- Helder Cruz
28 replies so far
View Ocelot's profile
Ocelot
2006 posts in 2693 days
#1 posted 02-21-2017 07:45 PM
Use some oil on the thing as you drill – also, use at least “cobalt” bits.
View diverlloyd's profile
diverlloyd
2870 posts in 1912 days
#2 posted 02-21-2017 07:50 PM
Yes you can drill any steel depending if you have the right bit. Put some oil on it and push down hard while pulling the trigger on and off. Don’t hold the trigger down that is what beats the bit and ruins your bits it’s more so that way on stainless
View sawdustdad's profile
sawdustdad
364 posts in 940 days
#3 posted 02-21-2017 07:54 PM
Depends on the quality of the drill bit, the type of drill bit and the hardness of the steel. Most twist drills are ground with tip angles appropriate for most materials, including mild steel. Cheap bits from Harbor Freight are not going to work or last, so buy good quality drill bits. Even then, they can be resharpened or may need to be if misused.
Yes, add some oil to the cutting process to keep the bit from overheating. As an example, I had to drill 3/8 in holes in some AR400 plate steel—hardened (abrasion resistant) steel. I got half way through the 3/8 in plate before the drill bit quit cutting. Sharpened it, and added oil. It went through that plate and 5 more without any hesitation. You can use pretty much any oil you have around, it doesn’t need to be cutting oil.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
heldercruz100
#4 posted 02-21-2017 08:03 PM
Thanks for the tips everyone, just one more thing, this is gonna sound joke, but it isnt.. Is it ok if I use engine oil?? I have some left from the last oil change, its new, but too old to put in the car..
-- Helder Cruz
View tomsteve's profile
tomsteve
796 posts in 1274 days
#5 posted 02-21-2017 08:03 PM
rpm is important,too.
diverlloyd
#6 posted 02-21-2017 08:07 PM
Yes old oil is fine
View HokieKen's profile (online now)
HokieKen
5655 posts in 1193 days
#7 posted 02-21-2017 08:23 PM
What kind of drill bits are you using? It has to be harder than the steel you’re drilling. For drilling steel, you need a HSS or carbide/carbide tipped bit. All of the above suggestions are good ones but still won’t work if you are using a cheap, mild steel bit intended for wood use only.
-- Kenny, SW VA, Go Hokies!!!
View jbay's profile
jbay
2430 posts in 954 days
#8 posted 02-21-2017 08:26 PM
Sometimes it’e easier to start with a smaller hole and increase the size as you go up.
View William Shelley's profile
William Shelley
576 posts in 1524 days
#9 posted 02-21-2017 08:41 PM
Yes, add some oil to the cutting process to keep the bit from overheating. As an example, I had to drill 3/8 in holes in some AR400 plate steel—hardened (abrasion resistant) steel. I got half way through the 3/8 in plate before the drill bit quit cutting. Sharpened it, and added oil. It went through that plate and 5 more without any hesitation. You can use pretty much any oil you have around, it doesn t need to be cutting oil.
- sawdustdad
I thought I should mention, I have this set of 3 stepped drill bits from harbor freight, and I’ve drilled over a hundred holes through 1/4” mild steel with the 6-step bit (the one pictured on the right), with oil and with my drill press. Probably 400-600 RPM. The bits are still holding up great.
http://www.harborfreight.com/3-piece-titanium-nitride-coated-high-speed-steel-step-drills-91616.html
-- Woodworking from an engineer's perspective
View Iamjacob's profile
Iamjacob
48 posts in 2681 days
#10 posted 02-21-2017 08:52 PM
Most likely you need to slow down. You almost cant drill too slow as long as you aren’t stalling to motor of your drill. Use of a drill press is best as you can use the slower pulleys but a hand drill will work.
When drilling steel you absolutely need to be pushing hard enough to be removing metal as the bit turns. If you are not removing metal as the bit is turning then you are rubbing the cutting edge of the drill bit and rapidly dulling it.
When drilling metal, you really do get what you pay for when it comes to drill bits. If you got your drill bits from harbor freight then don’t expect to get very far with them. Good quality drill bits will turn mild steel into swiss cheese with little effort.
jbay is correct. Start with a pilot hole and then step up in bit size. Make sure the the pilot hole is at least as large as the web thickness (see photo (b)) as the next size drill bit. The point of a normal drill bit does not cut but pushes the material out of the way so the flutes can remove it. A pilot hole allows the flutes of the bit to cut efficiently.
View Tim's profile
Tim
3812 posts in 2016 days
#11 posted 02-21-2017 09:01 PM
If it’s not making any progress the bit is probably dull. If it is a half decent quality bit and you learn to sharpen it, it will cut a lot better. +1 to what others said about using oil, lower RPM, and enough pressure. The amount of pressure affects the feed rate and the feed rate and RPM (speed) need to be in balance basically for the material you’re cutting.
Also as others said changing the drill point geometry can help a lot for different materials but that’s not a beginner topic really.
If you’ve got a super cheap bit none of the above will matter much.
View waho6o9's profile
waho6o9
8242 posts in 2632 days
#12 posted 02-21-2017 10:00 PM
http://www.harryepstein.com/index.php/catalogsearch/result/?q=drill+bits+us+made
I purchased this one:
http://www.harryepstein.com/index.php/norseman-29-pc-drill-bit-set.html
Great advice above. Use your used engine oil, step drill it with good bits and you’re done.
View Maximum's profile
Maximum
22 posts in 538 days
#13 posted 02-21-2017 10:33 PM
jbay has the right idea…that plus the oil.
View canadianchips's profile
canadianchips
2602 posts in 3052 days
#14 posted 02-21-2017 11:11 PM
If you have good drill bits you do not need to drill pilot hole.
I have chipped good bits because SOMEONE thought a pilot hole was a good idea !
I also use “Brake Cleaner”
An old timer machinist showed me that trick…Works well.
View jbay's profile
jbay
#15 posted 02-22-2017 12:23 AM
- canadianchips
I never have chipped a bit, drilled many a hole that way.
If you were using good bits then why were you drilling a pilot hole? lol
But I see you have me blocked so I see where your coming from.
(This is like the 3rd thread I see you have come behind me to disagree.)
showing 1 through 15 of 28 replies
