Delta 36-725 Table Saw BELT?
Forum topic by JKMDETAIL posted 02-21-2017 06:33 PM 1044 views 0 times favorited 2 replies Add to Favorites Watch
View JKMDETAIL's profile
JKMDETAIL
214 posts in 1799 days
02-21-2017 06:33 PM
Topic tags/keywords: tablesaw
I love my saw. It is about two years plus old and had no real problems until recently. I can stall the blade out. The motor does not seam to be stalling out but the blade is. Was wondering if there is a belt under all that stuff. I have looked at the parts diagram and cant tell for sure. If so is there a part number available.
2 replies so far
View Tennessee's profile
Tennessee
2880 posts in 2658 days
#1 posted 02-21-2017 07:00 PM
I checked eReplacements.com, and brought up the exploded diagram.
No belt.
I’d guess your blade flange washers are glazed, or the blade nut is just not tight enough.
If you were stalling the actual motor, I’d think you’d be popping breakers.
View pfleming's profile
pfleming
86 posts in 1358 days
#2 posted 08-08-2018 09:41 PM
I hope you’ve figured this out by now, but in case you haven’t, there is a belt on these saws. It’s a very short serpentine style belt that connects the blade arbor and the motor pulley. You have to remove the front cover, then take the three screws out of the blade arbor assembly to change the belt. There is no tensioner either, it’s tensioned by the distance and belt length. I did the same thing on mine not too long after I got it and had Delta send me a new belt, then I replaced it myself. It’s really not too bad of a job at all. Just don’t break the small bolts!!!
-- Patrick, Mississippi
