MILLING
Forum topic by 52areaguard posted 02-21-2017 06:05 PM 470 views 0 times favorited 5 replies Add to Favorites Watch
View 52areaguard's profile
52areaguard
1 post in 574 days
02-21-2017 06:05 PM
Topic tags/keywords: question
Hi, I am currently active duty which is why I am asking this question and I am wondering if it would be wise to cut my trees down and let them dry for five years before milling them into lumber? Your opinions, experiences, and any general info you have on this topic would be appreciated.
Of course I would de-bark the logs before letting them sit to dry.
5 replies so far
View Monte Pittman's profile
Monte Pittman
29783 posts in 2452 days
#1 posted 02-21-2017 06:09 PM
Welcome to Lumberjocks.
Cutting thick slabs and properly stickering and stacking in a storage area would be better.
View sawdustdad's profile
sawdustdad
364 posts in 999 days
#2 posted 02-21-2017 06:14 PM
Cut the lumber while green. Sticker and dry the boards. If you leave the logs whole you will induce checks (cracks) from differential drying that will run throughout the logs, making much of the wood useless (or less useful).
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View rwe2156's profile
rwe2156
3068 posts in 1595 days
#3 posted 02-21-2017 06:59 PM
Yes, wait till you get back then cut and mill while green.
Depending on wood species, leaving them around can also result in insect damage.
View HerbC's profile
HerbC
1785 posts in 2973 days
#4 posted 02-21-2017 07:41 PM
Unless the trees are dying off now you would gain five years of growth if you don’t cut them now. Once they are cut you will get the best results by milling quickly into lumber and then properly air drying them followed by kiln drying if necessary and appropriate for the type of lumber and intended use.
Good Luck!
Thank you for your service.
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View tomsteve's profile
tomsteve
807 posts in 1333 days
#5 posted 02-21-2017 08:00 PM
welcome to the forum!! there are quite a few risks/consequences to letting logs sit for years on end before milling. maple is one that it doesn’t take long to start deteriorating. in fact, its possible to have a log that could be perfectly white if milled ASAP, but just sitting a few weeks will give it streaks.
imo, its best to mill as soon after cutting as possible.
theforestryforum.com is a great place with lots of experience and information on milling. you may want to check em out.
