Question on arbor pulley
Forum topic by HavanaNights561 posted 02-21-2017 04:44 PM 479 views 0 times favorited 10 replies Add to Favorites Watch
View HavanaNights561's profile
HavanaNights561
10 posts in 750 days
02-21-2017 04:44 PM
Hey guys, a couple weeks ago I purchased a Jet 10” Table Saw (JWTS-10JF) from a local guy. It was working great no complaints, super quiet, I restored its back to no rust and painted it. Anyway, today I was making my first thin rip on it and suddenly the belt popped off. Turned it off and when I looked, the arbor pulley had come off. I don’t know much about the mechanical part of these machines so my question is, how do I go about repairing it? The pulley seems to be in good shape. Do I need something else to put the pulley back on? Also what do you guys think is the cause of it popping off?
For reference, I am talking about part #106 on page B http://www.ereplacementparts.com/jet-jwts10jf-708301-table-saw-parts-c-32652_32759_168412.html
10 replies so far
View Mark Shymanski's profile
Mark Shymanski
5623 posts in 3949 days
#1 posted 02-21-2017 04:49 PM
Was there a keyway or woodruff key or set screw or something that worked itself loose? A picture of the shaft and what the inside of the pulley looks like now may be helpful.
HavanaNights561
#2 posted 02-21-2017 05:00 PM
- Mark Shymanski
I’ll have to take a picture of it, but when I looked at all the pieces that fell out I didn’t run into a key or set screw, just the pulley
View dday's profile
dday
168 posts in 1666 days
#3 posted 02-21-2017 05:14 PM
Part 108 in that diagram is a set screw that looks like it goes in the pulley to hold it on.
HavanaNights561
#4 posted 02-21-2017 08:10 PM
- dday
Is there anything else I would need to put this back in? Also, are these set screws available at hardware store, such as homedepot and stuff? Or do you guys think I’ll have to order it online
View maxhall's profile
maxhall
80 posts in 2438 days
#5 posted 02-21-2017 08:14 PM
you could most likely buy the set screw at home deopt/local hardware store. I would buy several sizes and use what fits
HavanaNights561
#6 posted 02-21-2017 08:41 PM
- maxhall
Sweet thank you! Also, do you guys know how far into the shaft the pulley goes? I honestly didn’t look at it when it was on before (I know my bad)
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#7 posted 02-21-2017 08:50 PM
There should be a key (#107 in the parts diagram which is 5mm x 5mm X 30mm) as well as a set screw (#108 in the diagram, which is a M6×10) to hold it on. Check the pulley to see if the set screw is still in it. And if you can’t find the key, you can get key stock at the hardware store or BORG. When re-installing, line it up with the motor pulley.
HavanaNights561
#8 posted 02-22-2017 04:07 AM
There should be a key (#107 in the parts diagram which is 5mm x 5mm X 30mm) as well as a set screw (#108 in the diagram, which is a M6×10) to hold it on. Check the pulley to see if the set screw is still in it. And if you can t find the key, you can get key stock at the hardware store or BORG. When re-installing, line it up with the motor pulley.
- MrUnix
Thanks brad! I found the set screw with the exact same size at home depot. However the key (Part #107) on the diagram it says it is discontinued so I’m not exactly sure how to go about finding that part.
View waho6o9's profile
waho6o9
8539 posts in 2814 days
#9 posted 02-22-2017 04:14 AM
HavanaNights561
#10 posted 02-22-2017 04:25 AM
https://www.google.com/search?q=Key+5x5x30&client=safari&rls=en&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjYxveH66LSAhUiS2MKHSFDDHkQ_AUICigD&biw=1628&bih=893
This part Key 5×5x30?
I m guessing it s in Metric and it s a key, or key way
- waho6o9
Okay thanks guys, Im currently on duty but this weekend i’ll try to find these two parts and put it all together, you guys have been a great help
