Looking for help cutting thin stock ebony - how to avoid chipping?
Forum topic by LarryH posted 09-25-2010 04:54 AM 1284 views 1 time favorited 7 replies Add to Favorites Watch
View LarryH's profile
6 posts in 2730 days
09-25-2010 04:54 AM
Topic tags/keywords: ebony chipping
I am working on a jewelry box with an inlaid design. I am having a problem cutting triangles from 1/8” thick ebony. I have tried taping the edges and providing support for the cuts with a piece of hardwood in front of the miter.
I can make the 90 degree cuts just fine, but cutting the hypotenuse is a problem. I’ve made 4 cuts and 3 of them have chipped.
Any help would be very much appreciated.
7 replies so far
View Bobmedic's profile
379 posts in 2731 days
#1 posted 09-25-2010 07:01 AM
Try sandwiching the piece between scrap or scribing the cut line with a utility knife.
#2 posted 09-25-2010 04:08 PM
Robert, Thanks very much! I sandwiched the piece as you suggested and my success rate improved dramatically! I really appreciate your help.
#3 posted 09-26-2010 01:00 AM
I’m glad it helped. That is what this site is for.
View Dark_Lightning's profile
3114 posts in 3038 days
#4 posted 09-26-2010 01:14 AM
Sandwiching also helps to prevent blowout from the backside of a piece of wood when drilling a hole.
-- Random Orbital Nailer
View BertFlores58's profile
1694 posts in 2852 days
#5 posted 09-27-2010 06:13 AM
Another technique… select a very fine saw blade.. There are blades that are special for plywood and that would do the job….
-- Bert
View MattinCincy's profile
128 posts in 3083 days
#6 posted 09-27-2010 06:23 PM
I would also consider making the hypotenuse parallel to the grain – that way the 2 acute angles would be much less likely to chip out and the 90 degree angle would be the only cross grain cut you have to deal with and since it isn’t acute, it will be stronger.
-- Wag more, bark less.
#7 posted 09-27-2010 09:47 PM
All really good suggestions. I’ve got a couple of more pieces I have to cut this week, and I’ll give some of these a try. Thanks!
