How do you mount a shelf on the wall with no hardware showing?
Forum topic by Mark posted 09-25-2010 02:18 AM 24378 views 1 time favorited 11 replies Add to Favorites Watch
View Mark's profile
Mark
1817 posts in 3513 days
09-25-2010 02:18 AM
I just want to know how to mount a shelf on the wall with no hardware showing looking like there is nothing supporting the shelf. I’m working on a shelf right now and just want to know how. Plz and Thx :)
-- M.K.
11 replies so far
View Moron's profile
Moron
5032 posts in 4133 days
#1 posted 09-25-2010 02:22 AM
two methods come to mind, ok 3
you can buy hardware that is almost invisible, which pinches the shelf and I have used them for glass shelving and wood shelving
you can screw the shelf to the wall, via the opposite sideof the wall
you can drill parallel holes into the back of the shelf, another set of holes in the bottom. Drive threaded rod into wall studs, slide shelf via holes onto threaded rod, insert nut onto threaded rod via holes drilled under the shelf, tighten nuts, plug bottom holes.
2 cents
View GMman's profile
GMman
3902 posts in 3937 days
#2 posted 09-25-2010 02:31 AM
•1 Measure the thickness and length of your shelf.
•2
Cut three wood strips to a length equal to the length of your shelf, plus 2 inches. For example, a 30-inch shelf would need strips cut to 32 inches long. Take the width of your saw blade into account while cutting.
•3
Cut two other wood strips to a length equal to the thickness of your shelf. A one-inch shelf would need one-inch strips. Take the width of your saw blade into account while cutting.
•4
Arrange the two short strips and two of the three long strips into a rectangular frame. The 2-inch edges of the short strips should abut the 2-inch faces of the long strips. Glue in place, then reinforce with three 1 1/2-inch wood screws per connection, a total of 12 screws.
•5
Cut the remaining strip to a width that matches the total width of the frame you’ve built. Mount that strip to the back of the frame using wood glue and six evenly spaced 1 1/2-inch wood screws per long strip.
•6
Sand all faces of the bracket. If desired, paint or stain to match or complement the shelf.
•7
Mount the bracket to the wall using 3-inch wood screws, each drilled through the back plate and into a wall stud behind. Position the bracket so it crosses at least two wall studs.
•8
Coat the inside of your bracket with wood glue. Slide your shelf into the bracket, then screw in place with one 1 1/2-inch wood screw for every 2 inches of board length. Screw in place on both the top and bottom faces. Wipe away excess glue.
Read more: How to Make Hidden Shelf Brackets | eHow.com http://www.ehow.com/how_6632475_make-hidden-shelf-brackets.html#ixzz10Ur2PQVh
View degoose's profile
degoose
7245 posts in 3594 days
#3 posted 09-25-2010 02:33 AM
Have a look at this post.
http://lumberjocks.com/projects/4302
View Lenny's profile
Lenny
1616 posts in 3766 days
#4 posted 09-25-2010 02:41 AM
Hi Mark. I guess there are mutliple ways to do it. The ones I have seen involve a rather substantial shelf in terms of thickness. That’s because the shelf is placed on a cleat or rods of some sort that support its weight. Here are a couple of links to look at. Do a Google search on “how to install a floating shelf” for other options. Good luck.
“Shelf 1”: http://www.diyadvice.com/diy/built-ins/shelves/floating-shelf/
“Shelf2”: http://www.ehow.com/how_7180729_build-floating-wall-shelf.html
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
View Mark's profile
Mark
#5 posted 09-25-2010 02:53 AM
ok thx alot gang….it cleared my mind up :)
-- M.K.
View richgreer's profile
richgreer
4541 posts in 3314 days
#6 posted 09-25-2010 02:55 AM
I’ve done this several times with sliding dovetails and screws hidden inside the dovetail.
View thiel's profile
thiel
394 posts in 3531 days
#7 posted 09-25-2010 02:57 AM
It’s a cheat, but ikea makes some great hardware for this. It’s called Ekby. A little hardware shows, but really an excellent easy and cheap solution.
-- --Thiel
35153 posts in 4640 days
#8 posted 09-25-2010 03:05 AM
Use a hollow core door for the shelf.
Cut it as wide as you want the shelf.
Cut a 2×2 so it will fit in the hollow portion.
Screw the 2X2 to the wall.
Slide the door (shelf) on the 2X2 and put some screws down ito the 2X2 and up from the bottom.
If the door is wide enough then you can get 2 shelfs from one door.
Wala
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
View MOJOE's profile
MOJOE
562 posts in 3508 days
#9 posted 09-25-2010 05:30 AM
French cleat!!!!
-- Measuring twice and cutting once only works if you read the tape correctly!
View Bobmedic's profile
Bobmedic
382 posts in 3041 days
#10 posted 09-25-2010 06:55 AM
Keyhole router bit or keyhole hardware gets hidden behind the shelf
View Mark's profile
Mark
#11 posted 09-25-2010 03:15 PM
okay so i went and bought the hardware for the floating shelf….funny thing is….it only comes with a shelf in a kit and it was cheaper to buy the kit than it was just to buy hardware to whip it up myself….the shelf is in my scrap bin (the shelf i bought) and the hardware is going with my project lol ….the shelf it came with was a piece of garbage
-- M.K.
