Help treating/sealing exterior beams
Forum topic by Scojo posted 02-19-2017 09:28 PM 304 views 0 times favorited 3 replies Add to Favorites Watch
View Scojo's profile
Scojo
3 posts in 370 days
02-19-2017 09:28 PM
Purchased a home in the CO foothills that has exterior beam/rafter work. There is some weathering that I’d like to address and treat. Any suggestions on products and application? See images.
3 replies so far
View Rich's profile
Rich
2295 posts in 498 days
#1 posted 02-19-2017 10:03 PM
It’s difficult to get a feel for the scale of the damage from the photos. Are you thinking about simply sealing the wood, or do you wish to try to restore it?
-- No matter how much you push the envelope, it'll still be stationery.
View dhazelton's profile
dhazelton
2689 posts in 2205 days
#2 posted 02-19-2017 10:11 PM
Did they cut the beams to inset the gutter? That’s a design element that’s destined to fail, especially in snow country. If it were me I’d cut those rafter tails off so the rot doesn’t wick up into the wood under the roof. If that’s unacceptable to you I’d try to bend sheet metal to cap them and slide that up as far as you can.
View EricTwice's profile
EricTwice
230 posts in 442 days
#3 posted 02-19-2017 10:33 PM
...cut those rafter tails off so the rot doesn’t wick up …. under the roof. (or) ... try to bend sheet metal to cap them and slide that up as far as you can.
- dhazelton
I agree with the above.
They should have been treated lumber in the first place and sealed right after they went up. If it is only weathering you can fill and paint. If it is rot you should remove and replace them. Rot only gets worse. (This is the way I was taught)
-- nice recovery, They should pay extra for that mistake, Eric E.
