Bandsaw Riser Block Drawbacks
Forum topic by Gene Labbe posted 09-24-2010 06:07 PM 1028 views 1 time favorited 4 replies Add to Favorites Watch
View Gene Labbe's profile
Gene Labbe
3 posts in 2735 days
09-24-2010 06:07 PM
Topic tags/keywords: question bandsaw
Hello All,
I’m considering purchasing a riser block for my 14” Jet band saw prior investing heavily in new blades. I’d like to know if anyone has experienced any negative effects to this mod. I guess I have it my mind that the increased length of the upper guide post will somehow adversely affect the saws accuracy when doing finer scroll or joinery work. I have a feeling this will turn out to be a non-issue, but I just thought I’d ask.
Thanks in advance,
-- Gene, Tuscaloosa, AL
View dbhost's profile
5687 posts in 3165 days
#1 posted 09-24-2010 06:45 PM
Not a problem as long as you upgrade the tension spring as well. At least on my HF band saw, the OEM spring just wouldn’t tension my blade. I upgraded to a Carter Cobra Coil, and Cool Blocks… It is as accurate as I expect ANY band saw to be…
I haven’t done any ultra fine stuff like fretwork, but I HAVE done plenty of tight curves for things like kick panels etc… I still get excellent results. It’s all in using good blades, and tuning the saw right…
-- My workshop blog can be found at, YouTube Channel
View DanCo's profile
66 posts in 2831 days
#2 posted 09-24-2010 07:12 PM
I have a Jet 14 inch with the riser. I have had no problems at all. In fact I think it was the best thing I did to the saw. You just have to make sure you tune it right after you install, and thats not any different than doing the initial set-up when you first got the saw (at least in my opinion). Good luck and enjoy.
-- Daniel
View David Kirtley's profile
David Kirtley
1286 posts in 2931 days
#3 posted 09-24-2010 10:02 PM
I had the same setup as dbhost. When I first upgraded, it could not tension the blade well with the stock spring. The blade still doesn’t track as well as before the upgrade but I need to give it a chance before I make any drastic decisions to take it out or anything. Still, the extra cutting height is nice but honestly, I have not cut anything that needed it.
-- Woodworking shouldn't cost a fortune:
Gene Labbe
#4 posted 09-27-2010 01:47 AM
Thanks for the replies and the heads up on the tension spring! I’ll be sure to swap that out as well.
