Repair Live Edge insect damage
« back to LumberJocks.com Site Feedback forum
Forum topic by Keekee posted 02-18-2017 09:39 PM 621 views 0 times favorited 3 replies Add to Favorites Watch
View Keekee's profile
Keekee
12 posts in 1165 days
02-18-2017 09:39 PM
I’m working on a Live Edge table. Pretty slab of spalted maple. It does have some damaged areas. I appears that some type of insect burrowed into the slab leaving a saw dust like substance in the voids. The saw dust is compact but friable. Before I put the finish on I want to seal the substance left behind by the insect. Shall I use Crazy Glue or an epoxy. If id do will it make a Mahloof type of finish blotchy. What do you suggest.
3 replies so far
View papadan's profile
papadan
3584 posts in 3363 days
#1 posted 02-18-2017 09:53 PM
Clean away any loose material with a wire brush. For a small spot just use CA and larger areas inject epoxy into it. Keep the CA or epoxy inside the damaged area and it should have no affect on your finish.
View EugdOT's profile
EugdOT
225 posts in 550 days
#2 posted 02-18-2017 09:56 PM
Epoxy the voids, checks and weak areas, i would not fill all of the smaller holes that the beatles it gives it character. If it’s a finish like arm and seal with a oil you will not notice the epoxy it will blend.
View MrUnix's profile
MrUnix
6703 posts in 2194 days
#3 posted 02-18-2017 10:01 PM
LOL – just so you are aware, that ‘saw dust like substance’ is insect poop :)
Just google “Frass”
I work a lot of spalted wood, and those insect holes are everywhere. Sometimes I’ll just leave it in there and stabalize with thinned polyurethane… sometimes I’ll dig it out and fill with epoxy, either neat or tinted depending on the project. Either way, unless you are painting the thing, you will generally not be able to hide it completely and it will take on a different look than the rest of the wood when finishing.
PS: I’ll take frass over a larvae any day! Nothing worse than turning a piece, hitting one, and having bug guts sprayed all over the shop!
