Looking for "different" way to mount an Excalibur overarm guard
Forum topic by Jason White posted 02-18-2017 07:24 PM 1242 views 0 times favorited 5 replies Add to Favorites Watch
View Jason White's profile
Jason White
114 posts in 3305 days
02-18-2017 07:24 PM
I just acquired a new Excalibur overarm blade guard for my Grizzly 1023 cabinet saw. Here’s a link to the guard I’m talking about…
The guard requires 40” to the right of the blade in order to bolt the boom arm to the saw. I have short fence rails and a cast-iron router table on the right side of the saw, so bolting the boom arm directly to the saw isn’t really going to work for me. And I don’t want to cut into the boom arm (make it shorter).
Looking for another way of mounting the boom arm. I’m thinking maybe I could build the boom arm into some kind of mobile cart. Then, when I need to use the router table on the right side of the saw, I can just wheel the Excalibur out of the way. Could this work? I’m guessing I’ll have to put some bricks in the bottom of the cart to counter the weight of the boom arm so the cart won’t tip over.
5 replies so far
View Mark Kornell's profile
Mark Kornell
1169 posts in 2465 days
#1 posted 02-20-2017 12:25 AM
That arm is fairly heavy. Cantilevered out as it is, you would need a very heavy cart base to keep it up right.
However, once you get the bracket attached to the saw, the over arm part easily lifts on/off via two pivots. Assuming the weight isn’t an issue and you have some place to put it. No need for a cart.
As far as distance to blade, I’d make a permanent extension to the table saw/router wing to get the mounting point at a distance from the blade that works. And just lift the arm on/off as necessary.
-- Mark Kornell, Kornell Wood Design
View marc_rosen's profile
141 posts in 3116 days
#2 posted 02-20-2017 12:54 AM
Hi Jason,
Several years ago I purchased the blade guard only and rigged it up to hang from a pivoting arm attached to the floor joists above. It worked well enough but I occasionally struck the arm with a board and it also blocked a lot of light from the cutting area.
In addition to your own idea of a cart with counter weights you could have some type of cable tether from the ceiling to help support the arm over your cutting area..
Hope you have some success soon. Marc
-- Windsurfing, Woodworking, Weaving, and Woodducks. "Most woodworkers are usually boring holes"
View alittleoff's profile
539 posts in 1211 days
#3 posted 02-20-2017 03:33 AM
Build something like this, or use a steel pipe with a square plate bolted to the floor. Just set the new pipe into it or over it whichever works best. You would have to incorporate a tee into it somewhere.
View Kelly's profile
1950 posts in 2879 days
#4 posted 02-20-2017 05:02 AM
One of the most important things you can do with that is, toss the pathetic push stick on top and replace it with a shoe.
I’m not sure I understand why a router insert and such are a problem. The exact same unit, below, has been working for me for about ten years.
I like alittleoff’s approach, but you would still have to attach it to the table. You WILL have boards hitting the guard and lifting and pushing it.
4909 posts in 2428 days
#5 posted 02-20-2017 12:19 PM
I think you’ll have a helluva time getting a mobile cart heavy enough to hold that thing. I like that tripod design, that might be a choice.
