Miter Saw for crosscutting Table Saw for Ripping?
Forum topic by Beginningwoodworker posted 09-24-2010 02:48 AM 6775 views 0 times favorited 44 replies Add to Favorites Watch
Beginningwoodworker
13345 posts in 3913 days
09-24-2010 02:48 AM
I was taught by my shop teacher that the table saw is for ripping and the miter saw is for crosscutting, I am wondering do anyone else that do this? or I am crazy for listening to my shop teacher?
44 replies so far
View SnowyRiver's profile
SnowyRiver
51457 posts in 3721 days
#1 posted 09-24-2010 02:58 AM
I use my table saw for cross cutting all the time…especially for cutting wider boards and makiing panels etc.
I primarily use my miter saw for trim work and cross cutting thinner boards.
-- Wayne - Plymouth MN
27250 posts in 4062 days
#2 posted 09-24-2010 02:58 AM
Charles, a table saw can be used for either operation but a miter saw can only be used for crosscutting.
Beginningwoodworker
#3 posted 09-24-2010 03:01 AM
I own, both but I tend to use miter saw because I dont have a good miter guage.
View Jim Finn's profile
Jim Finn
2688 posts in 3162 days
#4 posted 09-24-2010 03:02 AM
I Always cross cut on my Miter saw amd almost always rip on my table saw.
-- No PHD just a DD214 Website> craftingcouple.com
View Abbott's profile
Abbott
2570 posts in 3544 days
#5 posted 09-24-2010 03:03 AM
A simple plywood sled can be built which is a great aid to crosscutting on a TS. There are plenty of them here on the Site…I bet the search for Crosscut sled or Table saw sled would return lots of hits.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
View docholladay's profile
docholladay
1287 posts in 3299 days
#6 posted 09-24-2010 03:30 AM
I have both, but personally, I actually prefer to do almost all of my cuts on the table saw – both crosscut and rip. You do have to use the appropriate jig/guide to do it safely and acurately. I feel like I can make the cuts more acurately with the table saw. Yet, probably the biggest reason is that the motor on my miter saw is much more noisy than the motor on my table saw. My miter saw is a makita. It isn’t a cheap tool. However, it is very noisy. The main difference is the universal motor that the miter saw uses vs. the induction motor on the table saw.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
Abbott
#7 posted 09-24-2010 03:42 AM
Here you go Click
View dbhost's profile
dbhost
5767 posts in 3472 days
#8 posted 09-24-2010 03:43 AM
I do occasionally cross cut on the table saw, but for stuff that is within the capacity of the miter saw, I use that. I was taught the same thing as you, but back in the day it was…
The Radial Arm saw is for crosscutting, the table saw is for ripping…
View jack1's profile
jack1
2117 posts in 4267 days
#9 posted 09-24-2010 03:47 AM
Hands down, the table saw is superior for rip cuts. Depending on the width and length of your wood and the table of your saw, it’s kind of a toss up. I do not think most of us would cross cut 1” x 10” x 12’ on regular table saws. You can but… If the boards were of a reasonable length, then the table saw works. I use the Miter for long thin and my panel saw for long wide (3/4” oak 4’x8’ for example).
As the old saying goes, “just cause you can, don’t mean you should”. Have safe fun out there.
Beginningwoodworker
#10 posted 09-24-2010 04:00 AM
I pefer my miter saw and circular saw for all my crosscutting needs.
View kosta's profile
kosta
946 posts in 3595 days
#11 posted 09-24-2010 04:26 AM
View MOJOE's profile
MOJOE
562 posts in 3509 days
#12 posted 09-24-2010 04:27 AM
Pick us a moderate miter gauge, attach a nice straight length of hardwood to the face and make cross-cuts with your tablesaw. The miter gauge extension will support your work, and back-up the piece you are cutting to reduce tear-out on the back side…...I save the miter saw for angle work, trim and molding.
-- Measuring twice and cutting once only works if you read the tape correctly!
View richgreer's profile
richgreer
4541 posts in 3315 days
#13 posted 09-24-2010 04:52 AM
It’s all a matter of personal preference. To some degree my table saw, miter saw and plunge saw (festool) are redundant. Almost any task can be done on at least 2 of these saws. Yet, depending on the job I almost always have a preference.
Beginningwoodworker
#14 posted 09-24-2010 05:06 AM
I might invest in a incra miter guage.
View cwdance1's profile
cwdance1
1159 posts in 3499 days
#15 posted 09-24-2010 05:07 AM
Once I built a sled I use my table saw for almost everything.
showing 1 through 15 of 44 replies
