The small lsaer engravors
Forum topic by papadan posted 02-18-2017 03:21 AM 483 views 0 times favorited 6 replies Add to Favorites Watch
View papadan's profile
papadan
3584 posts in 3424 days
02-18-2017 03:21 AM
Topic tags/keywords: question tip resource
500mw up to 2k mw. Who has them and how are they doing? I’m looking at one and want to make sure they are what they say. I see where all you need is a Jpeg image and they will print it.
View wuddoc's profile
wuddoc
283 posts in 3774 days
#1 posted 02-18-2017 03:44 AM
We purchased a small mini-laser for our shop to test. We found out that the unit had only a 1.5”x1.5” working surface and the low milliwatts did not do the job we expected. After further investigation we found a unit with 45 watts, a variety of lenses and a 12”x20” bed that works well for us. It engraves (raster) and cuts (vector) wood up to 1/4” thick.
The biggest challenge for us was learning how to use the software.
-- Wuddoc
View Madmark2's profile
Madmark2
379 posts in 644 days
#2 posted 02-18-2017 03:51 AM
I have a 1600mw 445nm 6×8 engraver. Works best with .BMP or .DXF files. You can use .JPG but you won’t easily get gray scale. Tip: be sure to set your images to 254 DPI or 100 dots per cm. They come with no instructions but if you’re patient the online docs are enough to build & run.
Check out http://lumberjocks.com/projects/261290 and http://lumberjocks.com/reviews/8018
M
papadan
#3 posted 02-18-2017 03:58 AM
Thanks guys, that 1600 is what I’m looking at Mark.
View lew's profile
lew
12154 posts in 3811 days
#4 posted 02-18-2017 05:55 PM
Don’t have one but the greater the power (milliwatts/watts) the more versatile it will be- IMO.
papadan
#5 posted 02-18-2017 08:37 PM
Right Lew, but higher power equals more $$$ and you get into the nitrogen tubes and maintenance cost skyrocket. I’ll stay below 2.5k mw and get everything I need out of them. And keep my budget under $200
Madmark2
#6 posted 02-18-2017 11:31 PM
For $185 delivered it can’t be beat. The first time I lased my logo it paid for itself vs the $200 cost of a branding iron . .
Paduke (?) Valentines day gift for my lady.
Definitely worth it.
M
