Cutting Thin Plexiglass (Plastic)
Forum topic by clieb91 posted 09-23-2010 10:42 PM 16843 views 0 times favorited 20 replies Add to Favorites Watch
View clieb91's profile
clieb91
3520 posts in 3810 days
09-23-2010 10:42 PM
Hey All, Looking for some suggestions on cutting some thin plexiglass. I am looking to do a few projects for kids that require a plexiglass shield and want to make sure I get the cuts nice and evn and I guess sand the edges so they are not sharp. Any one that has worked on something like this and could give me a few hints I would appreciate.
CtL
-- Chris L. "Don't Dream it, Be it."- PortablePastimes.com (Purveyors of Portable Fun and Fidgets)
20 replies so far
View Keen1's profile
Keen1
103 posts in 3721 days
#1 posted 09-23-2010 10:59 PM
Can you use lexan? I recently cut an 8X10 piece with my miter saw (and a fine tooth blade) to protect a picture going on a plaque. Very easy and sanded the edges. I’ve never tried plexiglass for such a purpose because the lexan is so easy.
If you can’t use lexan, (and assuming you don’t have a wet-saw at your disposal), I’d say bandsaw would be next best bet or a grinder.
No matter which method you use, tape over your cut lines to help reduce chip out.
-- Dad to 5, Son of The One
View Gene Howe's profile
Gene Howe
9941 posts in 3304 days
#2 posted 09-23-2010 11:57 PM
A glass guy turned me on to a plexiglass/lexan scoring tool, similar to one used on glass. Instead of a roller it has a fixed “V” shaped blade. If it’s 1/4” or less, I just score and snap.
Only for straight line cuts though. For curves, I use the BS or scroll saw. With either, I leave the paper on it as that reduces the melting and rejoining behind the blade.
View hairy's profile
hairy
2596 posts in 3407 days
#3 posted 09-24-2010 12:02 AM
http://www.ehow.com/how_2056832_cut-plexiglass.html
Once it’s cut, take a plumber’s torch and warm the edges. It will glaze them over and smooth them. Practice on the waste cutoffs.
-- My reality check bounced...
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3401 days
#4 posted 09-24-2010 12:18 AM
I cut striaght cuts on the table saw using a blade made for plexi and composits, works great.
View Sheila Landry (scrollgirl)'s profile
9220 posts in 2795 days
#5 posted 09-24-2010 01:02 AM
You can easily cut it on a scroll saw. You just need to slow down the speed a bit so the heat doesn’t build up from the blade and melt it back together. You get ultimate control and it is safe to do. Just a touch up sanding on the edge and it is good to go. :)
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View Abbott's profile
Abbott
2570 posts in 3179 days
#6 posted 09-24-2010 01:17 AM
I regularly cut Plexiglas on my table saw, it works very well. I usually always just use the blade that happens to be on the saw at the time and go slowly. But a 60 tooth blade will cut it perfectly. I have never tried a TS blade that was made to cut Plexiglas as was mentioned above but I would imagine it would work very well…I have just never needed one.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
clieb91
#7 posted 09-24-2010 02:57 AM
Thanks All.
Hairy, Thanks for the link.
Sheila, I have yet to add a scroll saw to my arsenal.. errrr workshop. :) though it is on my list.
CtL
View Claymation's profile
Claymation
165 posts in 2691 days
#8 posted 09-24-2010 03:00 AM
http://www.forrestblades.com/nomelt.htm
-- Clay (Master Kindler) ~ Central VA
View Jim Finn's profile
Jim Finn
2599 posts in 2797 days
#9 posted 09-24-2010 03:06 AM
I have had bad luck cutting 1/8” plexiglass on my scroll saw but the bandsaw cuts it very well.
View surfin2's profile
surfin2
51276 posts in 3011 days
#10 posted 09-24-2010 05:16 AM
The cleanist cut I found was with a router…
-- Rick
View Dave's profile
Dave
11426 posts in 2715 days
#11 posted 09-24-2010 05:22 AM
has anyone tried to turn there blades around backwards. I have cut pvc and vinyl this way.
surfin2
#12 posted 09-24-2010 05:57 AM
Why would you cut pvc with the blade backwards, I’ve done it the normal way & it work’d just fine…
I’ve tried vinyl both ways & got the same results… I was told that it was a difference in chip out but I think its between Sharp & dullness… Save yourself some time use a sharp blade & cut it the regular way…
-- Rick
View JimDaddyO's profile
JimDaddyO
531 posts in 2954 days
#13 posted 09-24-2010 03:34 PM
I use a straightedge and score a line a bunch of times with a sharp utility knife. Then I clamp a board at the score line, with the score line on the edge of a table. Then I snap it. Sometimes a bit of sanding to clean it up.
-- my blog: http://watertoneworkshop.blogspot.ca/ my You Tube channel: https://www.youtube.com/channel/UCA5AretE3xPoVDV61AxUdUA?view_as=subscriber
View Jonnyfurniture's profile
Jonnyfurniture
59 posts in 2702 days
#14 posted 09-25-2010 02:23 AM
They make tripple chip blades for cutting plastics. I cut it all the time with a standard blade though. I raise the blade up a little to have some extra down cut action. I never understood how the backwards blade thing is supposed to work. I guess the sharp edge of the carbide scrapes away material. Seems a silly thing to do and plexi would take a long time to cut.
View peteg's profile
peteg
4215 posts in 2698 days
#15 posted 09-25-2010 03:34 AM
As the others say, a regular tungsten blade will cut good, dont rush the cut, the main thing is to have your blade set right down so when it cuts you’re only showing about 1/4” max blade above the cut this will reduce chiping
