Delta 36-725 T-Square Fence - Is this OK or not?
Forum topic by liamtoh1 posted 02-17-2017 02:50 PM 3215 views 0 times favorited 20 replies Add to Favorites Watch
View liamtoh1's profile
liamtoh1
55 posts in 496 days
02-17-2017 02:50 PM
Topic tags/keywords: delta 36-725 t-fence
I purchased a new Delta 36-725 table saw from Lowes last weekend. Today during assembly, I noticed that the fence does not sit flat on the saw table. Upon inspection, I noticed that the back / bottom side metal piece is not parallel to the plastic piece. Here is the image of that section. Can someone tell me if this is OK or is that metal bend?
20 replies so far
View Ripper70's profile
Ripper70
995 posts in 904 days
#1 posted 02-17-2017 02:57 PM
Do you have a parts diagram that came with the saw? Might shed some light on this mystery.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View Lazyman's profile
Lazyman
1945 posts in 1383 days
#2 posted 02-17-2017 03:21 PM
That is the way it is supposed to be. It makes it easy to hook on the back rail when you are putting it back on the saw .
Ripper70
#3 posted 02-17-2017 03:28 PM
- Lazyman
So, if Layman is correct, there must be something else out of whack to prevent the fence from sitting flat on the table. There are adjustments that can be made to the fence itself to correct parallelism, etc. You may also want to make sure that your guide rails are properly installed and aligned. Lastly, make certain that the table top is actually flat and true.
View WhyMe's profile
WhyMe
1012 posts in 1556 days
#4 posted 02-17-2017 03:32 PM
The back tab is okay. If the extruded sides of the fence are not flat/parallel to the top (the sides should not drag on top) they can be adjusted by loosening the bolts through the large square holes in the bottom of the center fence body. The back tab can also be adjust forwards and backwards as needed to tighten or loosen the fence when the handle lock is in the locked position.
Explain exactly what you mean by not flat.
Lazyman
#5 posted 02-17-2017 04:08 PM
Just to make sure that I understand what you mean by not sitting flat…
I assume that you mean that from front to back it is not the same? That is not really an issue. As long as the face of the fence is 90 degrees to the table, it will be fine. The only time that comes to mind that front to back unevenness would be a problem is if the edge you are running along the fence is wedge shaped or very thin, for example, so that the edge can slide under the fence, causing it to be able to slide in or out or wedge under the fence at some point as you run it along the fence. That can be dealt with using an auxiliary or sacrificial fence that sits flush on the table.
Note: The primary purpose of that metal clip on the back is to help lock down the back side when you lock down the fence. When you lock it down, it is pulled tight against the rail to reduce the amount of flex as a board is pushed up against it on the back side of the cut. Having it bent like that causes it to force the back of the fence downward as you lock the fence, making it less likely to flex. At least that is my assessment anyway.
View simoncpj's profile
simoncpj
21 posts in 507 days
#6 posted 02-17-2017 04:31 PM
I have one I just set up. What you are seeing should not matter in use. There are three adjustments you can, and should make to the fence.
First is parallel to the miter slot. There are two screws, one one either side of the T that rides on the front rail, but on the face inside the slot.
Second is to make the fence vertical and 90 to the table. Those are the screws on the top of the T.
Finally, my fence was not square on both sides so I loosened the bolts accessed through the bottom and shimmed it (business cards were perfect).
View dday's profile
dday
150 posts in 1425 days
#7 posted 02-17-2017 04:41 PM
I had to adjust mine in the front by the Tee to get it to glide smoothly across the table. Works like a charm once you dial it in.
liamtoh1
#8 posted 02-17-2017 05:52 PM
Thank you so much for all these responses. I am at work but will check into the various suggestions and update here later this week/weekend.
liamtoh1
#9 posted 02-17-2017 11:59 PM
Here is what I meant by “fence not sitting flat” on the table top. See the 2 pictures.
The lip of the fence (as shown in the 1st picture) is rubbing on the back rail. In the 2nd picture, I can see that there is very thin gap between the table top and bottom of the fence, which I think is the correct way for the fence to ride.
I think I need to probably adjust the fence somehow. Is there a guide?
I checked the following -
  • The cast iron is flat
  • Both the wings are flat
  • The jig to check the rail (the L shaped flat metal piece) also is flat on the wings or table top.
  • The transition from the table top to the wings is also flat.
The above things were checked using flat edge of a 2’ or 3’ level and the bubble from the level.
View patcollins's profile
patcollins
1685 posts in 2860 days
#10 posted 02-18-2017 12:11 AM
That looks like it is on the stamped steel wing, is the steel wing flat and mounted so that it is coplanar with the cast iron portion of the saw top?
liamtoh1
#11 posted 02-18-2017 12:17 AM
- patcollins
The fence does not touch the wing either on the front or back (it’s a little difficult to see in the 2nd picture). As shown on the 1st picture, the fence lip (which rides on the rear rail) catches on the rear rail.
patcollins
#12 posted 02-18-2017 12:30 AM
The fence does not touch the wing either on the front or back (it s a little difficult to see in the 2nd picture). As shown on the 1st picture, the fence lip (which rides on the rear rail) catches on the rear rail.
- liamtoh1
Like others I just don’t see that as being a problem unless I am not understanding what you’re talking about.
liamtoh1
#13 posted 02-18-2017 12:40 AM
- liamtoh1
Like others I just don t see that as being a problem unless I am not understanding what you re talking about.
- patcollins
The issue: The fence (unlocked) does not glide at all. The front side (where you stand in front of the saw), the fence is movable. The back side of the fence is not movable. When I see from the side, I can see that the bottom side of the fence does not touch the table top at all (which I think is correct). So, this means, that something is preventing the fence from moving. That something, as I see it, is the metal tab/lip that goes under the rear rail. The metal lip catches on the rear rail.
I am sorry, if I am still unable to explain it correctly. I just now re-read “thetinman” review and setup of the rails and would have to re-do that all over again to rule any other issue with the setup.
View Stewbot's profile
Stewbot
199 posts in 1079 days
#14 posted 02-18-2017 12:58 AM
When I move my fence (same saw) the fence locking lever needs to be mostly vertical to slide well. Also check the allen screws at the front of the fence used to square the fence to the blade, Maby they are too tight and not giving you enough play when sliding the fence.
Edit: Brads image is what im suggesting, pictures worth 1,000 words.
-- Hoopty scoop?
MrUnix
6703 posts in 2194 days
#15 posted 02-18-2017 12:59 AM
Sounds like the fence is sitting too far forward (towards the operator) and needs to be moved back a hair. Have you tried adjusting the alignment screws (“C” in the diagram) to move it (towards the back of the saw) a little bit?
If that don’t work, a pair of vice-grips would :)
