Made another jig for my sled
Forum topic by Woodchuck2010 posted 02-17-2017 03:15 AM 828 views 0 times favorited 6 replies Add to Favorites Watch
View Woodchuck2010's profile (online now)
Woodchuck2010
721 posts in 999 days
02-17-2017 03:15 AM
This is another “Nick Ferry” designed jig for the sled. It’s a tenoning and spline jig. I’m going to make a little nicer one now that I know what I’m doing. lol
-- Chuck, Michigan,
View Rich's profile
Rich
3641 posts in 730 days
#1 posted 02-17-2017 05:28 AM
Nice design. I still have my old Delta tenoning jig — which serves me well — but I am so pleased with the new technologies in woodworking. From safety to precision. It’s a great time to be a woodworker.
Thanks for sharing.
View Lazyman's profile
Lazyman
2476 posts in 1528 days
#2 posted 02-17-2017 03:34 PM
Great Idea. Makes me wish that I had put some T-track in my sled.
How did you make sure that the t-track was perfectly parallel to the blade? I had to use the 5-cut routine to fine tune my fence after it was put together so I cannot quite wrap my mind around how to get that sort of accuracy with the T-track.
View tealetm's profile (online now)
tealetm
97 posts in 998 days
#3 posted 02-17-2017 04:36 PM
I assume that the t-track only uses one bolt/knob and references off the 90degree back? if thats the case Lazyman, the t-tracks wouldn’t need to be precisely parallel to the blade.
View BurlyBob's profile
BurlyBob
5911 posts in 2406 days
#4 posted 02-17-2017 04:41 PM
That’s pretty darn impressive. I might have to try building that whole Nick Perry system.
View Woodknack's profile
Woodknack
12369 posts in 2521 days
#5 posted 02-17-2017 07:29 PM
I have to say it looks like a nice system. Nick Ferry strikes me as a smart guy.
Woodchuck2010
#6 posted 02-17-2017 08:40 PM
I assume that the t-track only uses one bolt/knob and references off the 90degree back? if thats the case Lazyman, the t-tracks wouldn t need to be precisely parallel to the blade.
- tealetm
Correct. There is another slot for a bolt in the rear, but Nick says it works just fine if it’s up against the fence. I’ve only tested one piece and it’s quite accurate. Just follow his plans, and it all works out. lol One thing I changed was the elimination of the slots cut into the back fence for the t-track bolt insertion. I instead drilled access holes in the t-track to insert the bolts. I like the cleaner look AND you aren’t limited to a certain length bolt for the jigs.
Before
After
Heres the hole in the T-track. Works great
-- Chuck, Michigan,
