louvered octagon
Forum topic by dburly posted 02-17-2017 12:35 AM 735 views 0 times favorited 7 replies Add to Favorites Watch
View dburly's profile
dburly
2 posts in 585 days
02-17-2017 12:35 AM
I’m in the planning stage of a cupola, I wanted to have louvered octagons on each side
I have build a jig to cut the grooves in the straight side stiles with a router.
But for the angled stiles ?? Ill need some kind of compound miter cut.
Any ideas out there
7 replies so far
View Lazyman's profile
Lazyman
2399 posts in 1508 days
#1 posted 02-17-2017 03:39 AM
How about making frames for the louvres that are square and make the vertical supports for the cupola cut so the sides form the angles? Does that make sense?
View jerryminer's profile
jerryminer
944 posts in 1562 days
#2 posted 02-17-2017 06:03 AM
I think the easy way to handle this is to make a square frame with louvers and then cover with octagon trim, something like this:
You will have to work out flashing and siding details.
View jbay's profile
jbay
2604 posts in 1020 days
#3 posted 02-17-2017 12:10 PM
Make the Octagon. Put a dado blade in your table saw and tilt it to the angle you want for the louvers. Make your cuts in the Octagon and put in the louvers. They would have to be through cuts.
Just don’t raise the blade high enough to go all the way through the top of the frame.
Then trim the louvers flush with the sides. You could add another trim step around the octagon to hide the edges of the louvers. (Make it thicker than the octagon frame)
Lazyman
#4 posted 02-17-2017 02:49 PM
Those are octagonal attic vents. This is an octagonal cupola:
Assuming that is what you are asking about, if you put the angles in the corners you can rip them on a table saw with blade tilted at 22.5 degrees. In fact if you make a square frame, you can cut the angles after the louvered frames are made and just join them at the corners to make the octagon.
BTW, here is a a handy octagon layout calculator that may be useful for computing the dimensions to match your needs.
dburly
2 posts in 585 days
#5 posted 02-17-2017 10:13 PM
I thank you all very much, just as I was ready to change design, you all come up with a way!
MY first post here, glad I picked your site
when I get done ill post a pic
THANK AGAIN DAN
View jbay's profile
jbay
#6 posted 02-17-2017 11:42 PM
- Lazyman
”I wanted to have louvered octagons on each side
Just going by what he said and jerryminers drawings, thought that’s what he wanted.
THANK AGAIN DAN
- dburly
Looking forward to seeing the finished project,
Good Luck!
View jbay's profile
jbay
#7 posted 03-26-2017 06:58 PM
You still around or just a one and done?
Did you make it?
