My planer stand was made of screws... but I forgot about those couple nails.. until it bent in half.
Forum topic by newbiewoodworker posted 09-22-2010 02:53 AM 1356 views 0 times favorited 9 replies Add to Favorites Watch
View newbiewoodworker's profile
newbiewoodworker
668 posts in 2698 days
09-22-2010 02:53 AM
I almost finished my planer stand. I was putting on the legs when I decided to flip it over, to see how it was… the nails I had used to start the project with, since I was out of screws, mostly bent in half.. a few sheered… without the planer on it.. just its weight alone… And these were not pins either… some of them were in excess of 3in long… The rest that was made with screws was fine…
So tommorows plan is to finish screwing it…together that is..caught ya….:)..
So class.. what was todays lesson… “Nails are bad, and screws are good”..
On a side note, Delta finally called, they put through the authorization to have someone out to fix my saw… about time…
-- "Ah, So your not really a newbie, but a I betterbie."
9 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3584 days
#1 posted 10-09-2010 02:03 PM
The nails sheared off?! Just how heavy is this table?
View jusfine's profile
jusfine
2422 posts in 2797 days
#2 posted 10-09-2010 05:16 PM
Hard to understand how the nails sheared…
Heres a little video, not scientific by any means, and not exactly “shear strength”, but it does demonstrate some properties of nail strength…
http://www.metacafe.com/watch/967794/shear_strength_of_nails_drywall_screws_construction_screw/
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Raftermonkey's profile
Raftermonkey
560 posts in 2784 days
#3 posted 10-09-2010 06:35 PM
Thats kinda what I was thinking Randy. I frame houses for a living and have built miles and miles worth of homemade scaffolding. When I first started I was scared of the scaffolding so I nailed the heck out of it. Then the boss man made me tear down the scaffolding that I nailed up and well… I just use about three nails now. I used to know the shear strenght of different size nails but I have forgotten what they are. I do know that a naill will bend and pull out way before it will shear.
-- -Zeke- "I hate to rush off, but I gotta go see a man about a log"
newbiewoodworker
#4 posted 10-09-2010 07:03 PM
They were small ribbed finish nails. Maybe 1in-1.5in… But the larger nails, were big old framing nails… Those bent…
As for the weight… it was heavy… close to 60lbs, BEFORE I added the planer… That probably added another 60lb or so…
Rick Dennington
5656 posts in 3065 days
#5 posted 10-09-2010 07:18 PM
Newbie,
Never use a nail when screws will work better….Certain applications apply when to use one or the other.lol..
I know in the past, I’ve made the wrong use of one or the other, and paid dearly for it..Live and learn….lol.
-- " Don't pet the sweaty things, and don't sweat the petty things."
jusfine
#6 posted 10-09-2010 08:25 PM
Zeke, if I remember right it was 150 lbs for a 3 1/2 spike, I know when I framed we used to drive 1 or 2 spikes on each side of a 2×4 to make a temp ladder to climb up on steep trusses (12/12) and it had no problem with repeated use with a few 200 lb guys…
Newbie, you must have had faulty old nails…fortunate you didn’t damage any equipment!
newbiewoodworker
#7 posted 10-09-2010 08:45 PM
Yea… they were a bit rusty… they spent a week outside…
Believe me… I didnt put my equipment on there until I was sure I could sit on it(about 200#)...
Rick… believe me.. I use screws for everything.. I just didnt have a bit at the time, so I wanted to use nails… the next day I went out and got some star drive screws(I swear by these things… I have yet to strip one… knock on wood.. worth the extra dime..) I should have replaced the nails when I had a chance…
View GaryL's profile
GaryL
1099 posts in 2702 days
#8 posted 10-10-2010 01:59 AM
Sounds like you used paneling nails. These are hardened similar to drywall nails, thus being very hard and brittle. These will snap with very little twisting motion.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View EEngineer's profile
EEngineer
1089 posts in 3484 days
#9 posted 10-10-2010 04:18 AM
Nails are good. I use nails all the time. BUT…
When they first came out with the general purpose wood screws I fell in love. Easy to drive, they draw the parts together rather than forcing them apart as nails do. They don’t slip and loosen with time. And I even trust them in end grain – something I would never do with a nail.
Seriously, I find myself using few nails now. The only nails I use are air-nailed 18 Gauge brads – with glue. If I can’t screw it, I won’t nail it!
