Critical, but I'm hoping not terminal......?
« back to Hand Tools forum
Forum topic by nakmuay posted 02-16-2017 02:18 AM 876 views 0 times favorited 6 replies Add to Favorites Watch
View nakmuay's profile
nakmuay
81 posts in 1471 days
02-16-2017 02:18 AM
I found this handsome old gent on eBay, it’s a James Howarth coffin smoother I got for an “ok” price. I knew it had some checks in the ends and the mouth needed closing up from the picture, but now I need some advice on if it’s saveable.
I’m not so much worried about authenticity as I am about making it look right and work right. My plan was try get glue into the cracks where possible, clamp it , then put some dovetail keys in either end to hold it. Underneath I planed on putting a normal mouth plate in.
There a lot of deep cracks there, and I’m just not sure if it will hold together. I’m worried about the a crack high on the side wall where the wedge is installed, in not sure what I could do to save it.
Any help would be greatly appreciated.
Smitty_Cabinetshop
15519 posts in 2736 days
#1 posted 02-16-2017 02:26 AM
That’s on the cutter side, shouldn’t be an issue at all. Does the crack widen at all when the wedge is fully engaged? If not, I wouldn’t worry about it. If it does move (and again, I’d be surprised based on where it is), glue won’t fix it. Now, that V-shaped flaw below the crack is the greater concern to my eye.
nakmuay
#2 posted 02-16-2017 12:59 PM
The v-shape crack is ugly for sure. Nothing viually opens when I hit in the wedge, but if I apply direct pressure to the v shaped crack it will open slightly. There’s not much meat there either. I could laminate some strips to the outside, but it’s a sin for some thing so old
Any ideas for a game plan?
View JoeinGa's profile
JoeinGa
7739 posts in 2124 days
#3 posted 02-16-2017 01:18 PM
The v-shape crack is ugly for sure. Nothing viually opens when I hit in the wedge, but if I apply direct pressure to the v shaped crack it will open slightly. There s not much meat there either. I could laminate some strips to the outside, but it s a sin for some thing so old
- nakmuay
Maybe squirt some Superglue into the crack(s) and clamp it up … a bit of sanding and you may not even see some of them afterwards.
nakmuay
#4 posted 02-24-2017 01:39 AM
Thanks for the advice fellas!!!
I have a few older Stanley’s (3,4&5) and a few Veritas (6, LA block, router, & edge plane), but this is my first wooden plane. I’m amazed at how different it feel. I’m not the hugely sentimental type and I like what works, but this thing glides!
I put walnut dovetail keys front and back,
The mouth repair leaves about 1/16 gap, a little bigger than I would like but it works fine. I made the mistake of thinking the bottom was flat and square, fitting the mouth, then realizing it still needed some flattening work
And I superglued and clamped all the cracks up
Thanks for the help
Smitty_Cabinetshop
#5 posted 02-24-2017 01:55 AM
Very nice outcome, well done!
View Don W's profile
Don W
18938 posts in 2685 days
#6 posted 02-26-2017 09:12 PM
Excellent!
