Slab to Frame with pocket homes
« back to Joinery forum
Forum topic by cpuccio posted 02-15-2017 05:20 PM 363 views 0 times favorited 3 replies Add to Favorites Watch
View cpuccio's profile
2 posts in 523 days
02-15-2017 05:20 PM
Hi all, Bought the single kreg pocket hole jig as i have a few things round the house and yard that i wanted to try it with. The first is a workbench for my child. I could glue and screw it but want to take the slab off in a few years and repurpose it into his desk, ergo no glue. I made the slab and the frame and want to attach the slab to the frame with pocket holes in the inside of the 2×4 frame to slab.
The instructions show that jig being placed 1 1/4” from the end of a 2×4 assuming you are attaching the end. I am not. I tried it in the face of the 2×4 and screwd into the slab. Seems like barely 1/2’ if a 2” screw went into the slab. Thoughts hts or any help?
3 replies so far
View RobS888's profile
2405 posts in 1778 days
#1 posted 02-15-2017 05:27 PM
If I’m following along correctly you need at least a 2 1/2 inch pocket hole screw.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
View MT_Stringer's profile
3160 posts in 3164 days
#2 posted 02-15-2017 05:35 PM
I suggest you practice on some scrap until you get it right. For 2x lumber jobs, the 2 1/2 inch Kreg screws should be used.
View hotbyte's profile
991 posts in 2908 days
#3 posted 02-15-2017 06:11 PM
I did similar with a cut-off/router table but used 3/4 plywood for apron and re-purposed solid core door for top. It has worked well for several years. As mentioned, use 2-1/2” screws.
Also, for more substantial 2X work, Kreg has a HD version jig & screws. The screws have a much thicker diameter.
