Disolving PVA glue?
« back to Joinery forum
Forum topic by Bill White posted 02-15-2017 04:28 PM 4743 views 0 times favorited 6 replies Add to Favorites Watch
View Bill White's profile
Bill White
5097 posts in 4131 days
02-15-2017 04:28 PM
Topic tags/keywords: question
A very good friend has asked me to repair what WAS a nice walnut pedestal side table. Quite small, but with some nice features.
Problem is that at some time, an idiot slathered PVA glue all over the leg (3) joints and the tenon/mortice joint holding the small top to the column. This glue is all over the would-be joints and other surfaces.
The table will undoubtedly have to be refinished which is not the issue. I just need to figure a way to get all this crap out of (and off of) the joints so I can proceed with the real resto.
Once I get it clean, I will have to repair dowels, surfaces, and re-glue.
Any ideas as to how to get this old glue off without changing the color of the walnut?
Operators are standing by for your learned answers.
Bill
-- bill@magraphics.us
View HokieKen's profile
HokieKen
6550 posts in 1309 days
#1 posted 02-15-2017 04:51 PM
I have heard that methylated spirits dissolve PVA but that you have to use a syringe or something similiar to get it into the joints thoroughly. Never tried it, just remember reading it. I wouldn’t think it would affect the color of the wood but I’d put some on a piece of scrap first to be sure.
Good luck!
-- Kenny, SW VA, Go Hokies!!!
View JBrow's profile
JBrow
1366 posts in 1090 days
#2 posted 02-15-2017 06:37 PM
Bill White,
A non-water resistant PVA glue can be softened with water. I have also heard that methylated spirits, acetone, and vinegar can also weaken and/or remove PVA glue.
I have not tried methylated spirits, but I have recovered from major glue-up blunder with PVA (indoor, i.e. non-water resistant) glue. I let the 6” long dado and tongue joint soak in a bucket of water for I think about 6 hours. That was enough for the glue to soften and joint to come apart. I observed some staining on the wood along the water line but the staining was easily removed with normal sanding. Since a lot of water can enter wood setting in a bucket, I do not necessary recommend my bucket approach; but if water can be kept in a joint long enough it should come apart.
I have tried acetone and vinegar to remove cured non-water resistant PVA glue from the surface of a walnut scrap. The scrap walnut was where I mixed some of my own wood filler with PVA glue and wood dust. This left a layer of clearly visible glue that had cured for at least a week on the surface.
I soaked a paper towel with acetone and rubbed across an area of the glue (as if hand sanding). Some glue was removed but it was a slow go. When I soaked a paper towel with white vinegar and then rubbed the glue spot I was surprised to see the glue disappear from the surface. My conclusion is that both acetone and vinegar are effective agents for removing non-water resistant PVA glue on an unfinished wood surface but white vinegar works faster. But then I am not sure whether it was the acetic acid dissolved in water (that mixture constitutes white vinegar) or simply the water in the vinegar that was the effective agent. Since I did not try plain water, plain water might be worth a first try. If you try plain water, distilled water would reduce the chances of any mineral staining problems that might otherwise emerge if tap water is used.
Probably obvious; any finish that was applied over the glue would have to be removed to expose the glue before water, acetone, or white vinegar would be effective.
View Gene Howe's profile
Gene Howe
10971 posts in 3599 days
#3 posted 02-15-2017 07:18 PM
Vinegar will soften even Tite Bond lll.
View Loren's profile
10477 posts in 3818 days
#4 posted 02-15-2017 07:36 PM
hot knife. I’ve removed guitar bridges and
fingerboards this way. Also works on hide
glue.
The issue with solvents is they may damage
adjacent finished surfaces.
Steam also softens pva glue. I used to make
barrels (for conga drums) and experimented
a lot with steam and glue.
View wseand's profile
wseand
2796 posts in 3212 days
#5 posted 02-15-2017 08:09 PM
Acetone will pretty much eat any glue.
View Tennessee's profile
Tennessee
2887 posts in 2685 days
#6 posted 02-15-2017 09:04 PM
Agree with Loren.
Hot knife will soften and loosen without all the water, chemicals, and other liquids possibly allowing it to flow into areas before you get it off.
