Has anyone ever tried Polycryl on spalted wood?
Forum topic by Dick, & Barb Cain posted 09-21-2010 02:31 PM 2469 views 0 times favorited 4 replies Add to Favorites Watch
Dick, & Barb Cain
8693 posts in 4265 days
09-21-2010 02:31 PM
Topic tags/keywords: question spalted wood lathe finishing dick
I recently turned a bowl from some spalted Basswood. I had a heck of a time turning it, because the wood was so soft, & spongy. The fibers would pull out of the wood, no matter how sharp I kept my chisels . The only way I could finally get a decent finish, was sanding, & sanding. I’ve turned a lot of spalted wood before, but this was about the most difficult piece I’ve done. I have some more of this wood, & I’d like to try some sort of treatment first.
I’ll be entering this bowl as a project as soon as I take some pictures of it.
I wonder if anyone has ever tried this?
Here’s the finished bowl.
Click for details
6851 posts in 3945 days
#1 posted 09-21-2010 04:13 PM
Hi Dick;
I haven’t used it personally, but I was told by a turner to give the stuff a try, as it seemed to work for him.
Dick, & Barb Cain
#2 posted 09-21-2010 05:39 PM
Thanks Lee!
I think I’ll give it a try, it has to be better than nothing. It was a long process of sanding. It took me three times longer than usual to finish the bowl, besides Woodcraft has free shipping now.
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2822 days
#3 posted 09-21-2010 05:55 PM
I mix white PVA wood glue with water and let it soak in. once dry you get a great finish on my turned bowls. If in a rush a bit of hot air speeds the process. It also tightens up any loose fibre.. I’ve used this on Spalted Beech and I’m going to be doing it on a couple of door panels later today.
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
Dick, & Barb Cain
#4 posted 09-21-2010 07:42 PM
Thanks alba!
I’ll give it a try, I didn’t think of that.
I always use PVA glue to treat the ends of my green turning blocks, & have had excellent results with little or no checking.
