Low RPM motor
« back to Coffee Lounge forum
Forum topic by BUBBATAY posted 02-15-2017 02:37 PM 450 views 0 times favorited 3 replies Add to Favorites Watch
View BUBBATAY's profile
BUBBATAY
57 posts in 2371 days
02-15-2017 02:37 PM
I am attempting to configure a homemade router lift and found a 2.5 rpm motor on eBay but it is 50 hertz. is anyone aware if that would work on 60 hertz
3 replies so far
View ArtMann's profile
ArtMann
979 posts in 873 days
#1 posted 02-16-2017 12:16 AM
Are you in the US? 50 hz is a European standard and they normally use 220 volts. The 50 hz would probably work but but you would have to provide 220 volts. There are all sorts of name brand routers on eBay for low prices that are designed to work with 120VAC 60 hz. Why not just buy one of those instead. By the way, I don’t think you meant to say 2.5 rpm. Did you mean 2.5 horsepower?
View MrUnix's profile
MrUnix
6830 posts in 2256 days
#2 posted 02-16-2017 12:29 AM
It will run faster, which may or may not be ok depending on the motor design. As an alternative, you can get an incline motor out of an old treadmill which would work great. They are typically ~1/10hp deals that run on 120v (60hz), and already have the gear reduction acme screw and receiver that just needs to be attached to whatever you want to move.
View patcollins's profile
patcollins
1687 posts in 2922 days
#3 posted 02-16-2017 12:54 AM
Are you in the US? 50 hz is a European standard and they normally use 220 volts. The 50 hz would probably work but but you would have to provide 220 volts. There are all sorts of name brand routers on eBay for low prices that are designed to work with 120VAC 60 hz. Why not just buy one of those instead. By the way, I don t think you meant to say 2.5 rpm. Did you mean 2.5 horsepower?
- ArtMann
He is wanting a motor to raise the router, hence the 2.5 RPM.
Even at this speed something like this is going to be hard to control the height, what is needed is a stepper motor that will turn a specified number of turns so it raises/lowers the router an exact amount.
