Filling Holes in veneer
Forum topic by kdavid posted 09-21-2010 01:36 AM 2225 views 0 times favorited 2 replies Add to Favorites Watch
View kdavid's profile
kdavid
21 posts in 2990 days
09-21-2010 01:36 AM
Hi Guys, I’m attempting to fill a hole in a table in which its gone through the veneer. I read somewhere that you can take sawdust from the wood and create a slurry with glue that will closly match the wood color. My question is what kind of glue do I use and the recommended procedure for doing so. As always I appreciate any feedback…Thanks, Kirk
-- Kirk..... " Hope I die before I get old "
2 replies so far
View FredG's profile
FredG
139 posts in 3665 days
#1 posted 09-21-2010 01:52 AM
Hi Kirk,
You’ll get the best results using shellac sticks.
http://tlc.howstuffworks.com/home/how-to-repair-wooden-furniture-surfaces2.htm
-- Fred
View Gregn's profile
Gregn
1642 posts in 2952 days
#2 posted 09-21-2010 03:02 AM
A lot will also depend on the size of the hole. I have used this method to fill nail holes using sawdust and yellow tite bond glue. If its a larger hole you may have finishing problems with stain not taking if to much glue is used. It doesn’t hurt to try it, if all else fails and your not happy with the end results of what ever method you use. You can always put in a dutchman patch.
