Farmhouse Table Joinery
« back to Joinery forum
Forum topic by srich1222 posted 02-14-2017 02:17 PM 909 views 0 times favorited 7 replies Add to Favorites Watch
View srich1222's profile
2 posts in 401 days
02-14-2017 02:17 PM
Topic tags/keywords: farmhouse table
First off let me just say that after reading through the LJ forums, this is a great resource to gather information from much MUCH more experienced woodworkers than myself. I am relatively new to this hobby so forgive me if I ask dumb questions…
Last Spring I built a farmhouse table with the ana-white plans (I know I know…) The wife found the design and said “build this” so off I went to building. This was my first real experience building a piece of furniture of this size so I honestly had no other plans to go off of so I followed the instructions down to every detail. After reading the forums, I now realize that Pocket Holes are not the best type of joinery to use. Granted, the table still looks great with no cracks or twisting but now I’m literally sweating bullets hoping it doesn’t fall apart on me. I’ve attached some of our photos of the table below. I live in South Dakota if that matters.
SO…my question is what is the best type of joinery for a farmhouse tabletop where you still want to be able to see the seams between each board? Not that I don’t like the tabletops that you cant tell where the boards meet but I think this brings out character in the table, truly making it a farmhouse table. Other styles of table, not so much.
Thanks for the help!
7 replies so far
View avsmusic1's profile
223 posts in 617 days
#1 posted 02-14-2017 03:58 PM
Are you looking to be able to see fully through the boards where they meet on the top, or to have a notable seem?
If it’s the second, I think there are a number of options. If you like rustic then just don’t use cauls, biscuits, or dowels to align the boards. It’s going to keep the table top from being truly flat across the boards but it’ll highlight the seems and, imho, is ok on this style. Another option would be to use a v groove bit or something like that on the edges of the boards.
View mike02130's profile
167 posts in 604 days
#2 posted 02-14-2017 04:40 PM
Put a slight chamfer on the edges. Block plane or sandpaper
-- Google first, search forums second, ask questions later.
View Dustin's profile
464 posts in 672 days
#3 posted 02-14-2017 04:48 PM
- mike02130
I’ve always liked the tables where they used random strokes with a block plane to chamfer the edges for the rustic effect. IMHO, preferable to using a chamfering bit, but mainly because I like the seems not being perfectly uniform.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
15248 posts in 2550 days
#4 posted 02-14-2017 04:59 PM
What Mike said, +2.
It’s not the joinery used that allows (creates?) the look you want in a farmhouse table, but the state of the material being joined. I built a couple of these ana white tables for clients; the 2x material was planed flat and true, taking the radius corners off of the boards in the process. Join the boards into a top, no seams. If you want them, gotta restore the radius with either a router bit or a block plane.
2 posts in 401 days
#5 posted 02-14-2017 05:26 PM
- avsmusic1
I’m wanting to just have a notable seem. Not necessarily see all the way to the floor if that makes sense.
- mike02130
Got it, that makes perfect sense actually. Like I said, these LJ forums are awesome.
On a side note, what would be the best way to joint the tabletop with 2×8’s since I want to lean away from Pocket Screws? Would a glue-up be strong enough as a stand alone?
View TheFridge's profile
9079 posts in 1418 days
#6 posted 02-14-2017 05:35 PM
Glue is stronger than the wood when properly done
View Woodknack's profile
11297 posts in 2312 days
#7 posted 02-14-2017 06:23 PM
You’ve asked this question before. I like Mike’s suggestion the best. Heads up, I used to own a table with seams like that and you need to scrub them out occasionally with a brush.
-- Rick M,
