Needed Center Trunnion Powermatic 66
Forum topic by RichmanNot posted 02-14-2017 05:49 AM 594 views 0 times favorited 3 replies Add to Favorites Watch
View RichmanNot's profile
RichmanNot
39 posts in 746 days
02-14-2017 05:49 AM
Topic tags/keywords: part needed powermatic 66 trunnion cabinet saw table saw
Deleted – Problem resolved
-- "can't died in the poor house" (Because he always went around saying... "I can't")
3 replies so far
MrUnix
7103 posts in 2433 days
#1 posted 02-14-2017 05:58 AM
Does it still work as is? Looks like you could get rid of some of the ragged edges and continue to use it until a suitable replacement can be found.
Best bet would be to post an WTB ad in the BOYD section over at OWWM. And if you have a serial number, you can date the saw.
RichmanNot
#2 posted 02-14-2017 06:08 AM
Brad, It probably still works…. I did not get much of a chance to play with the saw, I began straight away tearing it down and have re-worked the 3 HP motor with new bearings from Accurate Bearing and was getting ready to replace the arbor bearings when I found the issue with the trunnion teeth being nearly gone.
I have posted on OWWM already and have made several other inquiries.
Hopefully someone has a second hand PM 66 that they are thinking of parting out and can help me out. Thanks for your reply.
- MrUnix
RichmanNot
#3 posted 02-19-2017 08:07 PM
Well, I have since determined that my center trunnion on my Powermatic 66 is “just fine”... It is made that way for some reason and the TEETH are A-OK.
Here is a photo of it all cleaned up.
But thanks for all the support. (I am learning about my saw one piece at a time)
