I've come across an old repair during sanding of an oak chair. What to do?
Forum topic by Prizen posted 02-13-2017 08:11 PM 1677 views 0 times favorited 9 replies Add to Favorites Watch
View Prizen's profile
Prizen
31 posts in 2066 days
02-13-2017 08:11 PM
Hey all
In the middle of sanding down oak kitchen chairs and came across this repair. Is it OK as is? Plan is to re stain in a new color.
9 replies so far
View Bill White's profile (online now)
Bill White
5072 posts in 4107 days
#1 posted 02-13-2017 08:13 PM
What repair? I can’t see a thing. :)
Bill
-- bill@magraphics.us
Prizen
#2 posted 02-13-2017 08:39 PM
What repair? I can t see a thing. :)
Bill
- Bill White
Great, leave as-is then! I guess!?
View TheFridge's profile
TheFridge
10334 posts in 1632 days
#3 posted 02-13-2017 08:59 PM
Bill
- Bill White
Ditto
View jerryminer's profile
jerryminer
944 posts in 1588 days
#4 posted 02-14-2017 08:08 AM
Leave it, but it may not take the stain well. Expect to touch up the repair with some extra color.
View papadan's profile
papadan
3584 posts in 3515 days
#5 posted 02-14-2017 09:16 AM
I will agree with everyone else if….... you take a fine point something and see if the repair material is rock hard or at all soft. If hard, go for it. If the repair material is soft it is some kind putty or glue and that will be a possible break point for that chair. If soft, you could dig out the repair material completely, including a little of the surrounding wood that is saturated by that material, and then repair with a good epoxy. I would cut out a piece of the chair leg and fit a new piece of Oak back into place. Then refinish the set of chairs. I can’t tell by that picture, the actual location of the repair on the chair. But when Uncle Bob finishes his big dinner and stretches against the back of his chair, you don’t want to have to start all over on the repair after picking his fat butt up off the floor! Just my thoughts, but you decide.
View rwe2156's profile
rwe2156
3092 posts in 1627 days
#6 posted 02-14-2017 02:29 PM
Sorry but I’m going to disagree with the others here.
If it is fixated with a screw ok, but if its simply glued (you sure that isn’t bondo?) it will not be a good repair going forward.
To properly fix a break like that you would remove material past the crack to good wood and dutchman a new piece of oak in place. It will be stronger and much easier to finish.
View johnstoneb's profile
johnstoneb
3014 posts in 2319 days
#7 posted 02-14-2017 02:37 PM
Is that actually a break or is it just an opening in the knot? It looks like it is just filler in an opening and shouldn’t affect anything.
-- Bruce, Boise, ID
View McFly's profile
McFly
273 posts in 1174 days
#8 posted 02-14-2017 03:47 PM
Is that actually a break or is it just an opening in the knot? It looks like it is just filler in an opening and shouldn t affect anything.
- johnstoneb
That’s what I’m seeing here – a knot that didn’t quite make it. If that’s a hard plastic wood type filler, you should be good to go, just know that this is definitely a weak point that could fail in the future.
TheFridge
#9 posted 02-14-2017 05:40 PM
I thought a knot. It wouldn’t hurt anything to cut it out and put another piece of oak in.
