Clueless...Deft over shellac? 1920s baseboards
Forum topic by NoCluePleaseHelp posted 02-13-2017 02:08 PM 690 views 0 times favorited 6 replies Add to Favorites Watch
View NoCluePleaseHelp's profile
NoCluePleaseHelp
2 posts in 525 days
02-13-2017 02:08 PM
Topic tags/keywords: question
While trying to clean years of dirt and stains from baseboards I discovered a shellac finish in this old house. So I Google my next step and discovered denatured alcohol will help me in my endeavor for clean baseboards! Well… I’ve applied and gently used steel wool to remove the nasty stains from years of mopping. It helped remove the mopping stains but also most of the color. I want to get the color back but do not want a shellac finish. After researching (back to Google) I have no clue what will adhere to my beautiful wood trim. Please help.
View Rich's profile
Rich
3206 posts in 645 days
#1 posted 02-13-2017 02:58 PM
It sounds like you’re down to clean, pretty much bare wood. Anything will adhere. By Deft, I assume you’re talking about brushing lacquer. That is one of my favorite top coats. I thin it and spray it, but in an environment like yours brushing makes sense.
Can you offer any more detail about color? What color was it, and what do you wish for a result?
View Lazyman's profile
Lazyman
2187 posts in 1443 days
#2 posted 02-13-2017 03:32 PM
Since water contact is likely to happen in the future due to mopping, you need to make sure that you use a finish that will not be a problem with water contact. I don’t have much experience with lacquer but the type of lacquer might determine how water resistant it is (?). Personally, I would probably go with polyurethane top coat but you could apply dewaxed shellac first to restore the natural color and put the poly coat on top of that for more water resistance. Shellac makes a great sanding sealer. Because of the age of the house, you might want to use an amber shellac to bring back the original color.
5017 posts in 2549 days
#3 posted 02-13-2017 03:35 PM
Shellac will allow most stuff to adhere well. Deft (or any NC Lacquer) would not be my choice. For baseboards I would want something that is quite a bit more durable, and maybe a whole lot less odor when being applied. Without considering the color part I would use a good quality varnish, or a good quality waterborne. The waterborne (think General Finishes HP or one of the others they offer) will dry quickly, and since the wood is probably still sealed with the shellac grain raising shouldn’t be a problem. But the color part may be a little tricky. Shellac does impart some color, but it would help to know what you are trying to get, also the wood the baseboards are made from.
NoCluePleaseHelp
2 posts in 525 days
#4 posted 02-17-2017 02:29 AM
Thank you! The man at my local hardware store helped me match the color. He was glad to help once he knew I didnt bring a 3ft piece of wainscoting in as a weapon. I used a rich mahogany and decided on a polyurethane finish. Wish I could post a picture of how well it turned out, next will be the handrail and stairs.
View Aj2's profile (online now)
Aj2
1509 posts in 1854 days
#5 posted 02-17-2017 04:20 AM
I’ve found shellac to be very durable then most woodworker will admit.My good friend Gary that lays hardwood floors has mentions to me more than once about old hardwood floors with shellac finishes.
I also have a spot outside my shop that still has a good lump of button lac that remains from a small jar I dropped several years ago.
It’s been thru rain and hot sun and it’s still there.It looks kinda gray but it’s holding on.
Aj
-- Aj
View Kelly's profile
Kelly
2044 posts in 3000 days
#6 posted 02-17-2017 06:56 PM
Years back, I had the pleasure of working the oldest Queen Ann in Olympia, Washington. Pretty much the entire house was cedar. Even the floors were cedar. They converted the attic to usable space, which meant adding to the floors.
I didn’t know how to match the new cedar to the old, but the primary contractor had a savy old fart who shared a secret with me – amber shellac. I tried it and it was a perfect match.
I can’t think of anything easier to touch up. No sanding needed, since the alcohol in the new coat melts into the last. That might be why the floors looked as good as they did, eighty years after the house was built.
I’m wondering if you have the same thing. If so, once you have the shellac on, just clear coat it with waterborne poly and you should have as durable as you need for baseboards. Too, you’ll know how to touch it up.
