Need a new belt sander
Forum topic by jobott posted 975 days ago 1755 views 0 times favorited 15 replies Add to Favorites Watch
View jobott's profile
jobott
27 posts in 1530 days
975 days ago
Hi Folks, well my 30 year old Wen belt sander started smoking and is telling me it’s time to replace it, so I am now in search mode for a new one. My current one is 3 X 18 belt size but I would also consider a 3 X 21. I have looked a some reviews and seen the Ridgids Models R2740 (3 X 18) $100 and R2720 (3 X 21) $120 on sale and Porter Cable for about $100 which is close to budget and there is also the Dewalt running about $200 which is higher than I want to spend but I wonder if its really worth the extra $$. I only use it occasionally so at this point I am leaning towards the less expensive ones. What are you other LJ’s using? Any recommendations?
-- Joe B
15 replies so far
View newbiewoodworker's profile
newbiewoodworker
659 posts in 996 days
#1 posted 975 days ago
The good thing about the dewalts, is that they have a fixture that mounts them vertically, so you can use it as a stationary. If you are talking about the one I am thinking of…
But if you only use it occasionally, then maybe going cheapest would be best… the good thing about Ridgid.. is the Lifetime Warrantee… but they never tell you is: the life time of the tool(when it breaks its surpased its lifetime :( ; or lifetime of the line… :) )
-- "Ah, So your not really a newbie, but a I betterbie."
View richgreer's profile
richgreer
4474 posts in 1243 days
#2 posted 975 days ago
Pardon me for being blunt but do you really need a hand held belt sander at all? I have one that I virtually never use. I find that an aggressive random orbital sander can remove material just as fast and I have less problems with uneven sanding.
On the other hand, I use my stationary belt sander a lot. Mine has a 6” x 36” belt and it removes material in a hurry.
newbiewoodworker
#3 posted 975 days ago
Its also good at reshaping your fingerprints in a hurry, incase you ever get wanted by the 5-o…. :)
jobott
#4 posted 974 days ago
I find that the belt sander is good for edge sanding and flattening edge joined boards. A ROS floats across the seam instead of flattening or evening in my experience, so I feel the belt sander is better for this type of woodworking. I have used a hand plane as well but my skills are not that high yet using this method ergo the use of the belt sander. I also have a stationary belt sander but it is more difficult to get the edges even on long boards with a stationary sander and impossible to see joined edges. The belt sander provides the control I need for these operations.
-- Joe B
View AuroraWoodworks's profile
AuroraWoodworks
191 posts in 1292 days
#5 posted 974 days ago
I have the dewalt. I bought the version that came with the sanding frame and stationary stand. I would never buy a belt sander without a sanding frame! It is impossible to burn an edge into your work when you use the frame. It turns a belt sander into a hand plane as far as the control you have. It is well worth the extra money.
-- Tony - Anchorage, Alaska
View DrDirt's profile
DrDirt
1783 posts in 1911 days
#6 posted 974 days ago
I really like the Bosch 1274
This is because I often flip it on the bench to use as a bench sander – and the flat top on the Bosch is great
http://www.amazon.com/Bosch-1274DVS-3-Inch-21-Inch-Variable/dp/B0000223HB/ref=dp_cp_ob_hi_title_1
It is running $163.00 right now.
-- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison
View mathom7's profile
mathom7
67 posts in 1080 days
#7 posted 974 days ago
Does anybody have the Ridgid 3” by 18” belt sander? I’m thinking about picking it up using the 20% rebate Ridgid is offering this month.
View Brandon's profile
Brandon
3749 posts in 1120 days
#8 posted 974 days ago
I’d add another vote for the Bosch 1274. It’s a great belt sander and the fact that you can flip it upside down (or stick it in a wood vise) is a plus. Also, there are a few attachments you can purchase for it.
-- "hold fast to that which is good"
jobott
#9 posted 973 days ago
Where do you get the Ridgid 20% off coupon??
-- Joe B
View syenefarmer's profile
syenefarmer
332 posts in 1249 days
#10 posted 973 days ago
I don’t use my hand held belt sander all that much myself but for the use I give it I’ve found this reconditioned Hitachi SB-75B more than adequate and certainly priced right. Don’t overlook reconditioned, many times they are the best buy.
View Apex's profile
Apex
9 posts in 1030 days
#11 posted 973 days ago
I like the Porter Cable models. They seem to be quieter than others.
Utah stair railing
-- www.apexcarpentryinc.com
View Abbott's profile
Abbott
2570 posts in 1472 days
#12 posted 973 days ago
That Bosch sander looks nice Dave, pricey but very handy.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
View Lee Barker's profile
Lee Barker
1887 posts in 1019 days
#13 posted 973 days ago
Has anyone compared speeds? Faster isn’t necessarily better; the slower ones would be my preference—less chance to dull the belt and burnish the wood.
I have owned both an old Skil worm drive and now a newer PC worm drive. They’re much easier to control than the sidewinders.
But, sadly, probably out of your budget.
Brandon
#14 posted 973 days ago
The Bosch is a variable speed sander.
mathom7
#15 posted 973 days ago
It’s not a coupon but a rebate from Ridgid.
http://www.ridgid.com/Download/lsa_eblast_rebate.pdf
Though I did pick up the Ridgid 3×18 variable speed sander today using a Harbor Frieght 20% coupon.
