Bandsaw maintenance crash and burn
Forum topic by unclearthur posted 02-13-2017 04:36 AM 902 views 0 times favorited 16 replies Add to Favorites Watch
View unclearthur's profile
unclearthur
180 posts in 1784 days
02-13-2017 04:36 AM
So I was trying to do a little bandsaw maintenance, and as usual within 60 seconds I had made things worse.
This was the original metal insert; it fell apart just under a little upwards pressure from my fingers.
16 replies so far
View MrUnix's profile
MrUnix
6706 posts in 2195 days
#1 posted 02-13-2017 04:41 AM
Those things are considered a maintenance item and get torn up over time… looks like yours is about due for replacement :)
You can buy them all over the place or make your own from aluminium, wood or recycled milk jugs (HDPE):
(same insert fits the bandsaw and my 18” Delta scroll saw)
unclearthur
#2 posted 02-13-2017 05:06 AM
How did you make your wooden inserts ..... I guess I could cut a rough 2 1/2” circle out of say 1/4” board and sand it to fit the outer diameter of the hole, but there is a 1/8” lip …...how do you cut the groove on a circular piece with that sort of precision?
woodbutcherbynight
4538 posts in 2405 days
#3 posted 02-13-2017 05:12 AM
- unclearthur
I made several at one time on the lathe.
MrUnix
#4 posted 02-13-2017 05:28 AM
Yup, on a lathe is the easiest. Turn a blank to 2.5” and then slice off pieces on the band saw. For the HDPE, I just melt some in a slightly oversized metal can and then throw it on the lathe to turn to final diameter. I originally used wood, but it is a bit flimsy. The HDPE is pretty stiff stuff and works much better (those shown are actually from fabric softner jugs, not milk jugs :). If you don’t have a lathe, I guess you could always get some 2.5 inch wood dowel and do the same.
unclearthur
#5 posted 02-13-2017 05:32 AM
That makes sense but I don’t have a lathe.
I found some plastic zero clearance inserts on the internet, $5 for an insert and $12 for delivery. Such is life in Canada.
View Kelly's profile
Kelly
2025 posts in 2940 days
#6 posted 02-13-2017 06:53 AM
You could set up a couple of “fences,” once on each side of the throat, then push the new plates in on a piece of Masonite or whatever. Just use an L-square to set up the fences (e.g., boards).
- unclearthur
- woodbutcherbynight
Kelly
#7 posted 02-13-2017 07:00 AM
I have a piece of diamond plate and cut the circles out using my jig saw. Once I get close, I run down to the line with a sander. I end up with press in fits.
I have a Powermatic and the plates I find everywhere are the wrong size, so making them is a must. I make a couple at a time.
I install the plate with the diamonds down. Be it the luck of the Irish or whatever, it’s a perfect fit in thickness too.
Once in a while the plate get loose in the throat and I just turn it over and hit it with a punch about one hundred twenty degrees out and it’s back to a tight fit.
View jbay's profile
jbay
2281 posts in 895 days
#8 posted 02-13-2017 02:11 PM
- MrUnix
I’ve never made them from Lay’s Potato chips before, seems kind of brittle?
View TheFridge's profile
TheFridge
9453 posts in 1482 days
#9 posted 02-13-2017 03:42 PM
Lee valley doesn’t carry them?
View Lazyman's profile
Lazyman
1952 posts in 1384 days
#10 posted 02-13-2017 03:50 PM
If you have a router table, you can make a simple jig to make your own large cylinders. Should work for plastic too. Simply use a straight of box bowl bit in the router and put your rough block in a jig like this. You’ll want to cut the corners off before mounting in the jig to speed things along. You raise the router until the cylinders are the desired diameter.
View bonesbr549's profile
bonesbr549
1546 posts in 3063 days
#11 posted 02-13-2017 05:19 PM
Get some jbweld mix it and put it back together. It will work
View rwe2156's profile
rwe2156
2925 posts in 1477 days
#12 posted 02-13-2017 07:20 PM
That makes sense but I don t have a lathe.
- unclearthur
I did the same for my little saw for me its not worth the time to make my own. I bought a pack of 3 for $8 + $6 shipping from Amazon. One will last a long time.
woodbutcherbynight
#13 posted 02-14-2017 05:26 AM
Think of this as good excuse to give for buying a lathe…..
unclearthur
#14 posted 03-03-2017 12:41 AM
So my replacement bandsaw inserts finally arrived in the mail, and they are zero clearance inserts.
Is there a clever way to create the slot for the blade kerf? Done it before on a tablesaw by raising the blade but not on a bandsaw …...
View Matt's profile
Matt
160 posts in 947 days
#15 posted 03-03-2017 01:48 AM
I just held the insert infront of the blade centered on the hole (making a heart like shape with my hands, with my thumbs moving towards the blade, the pointer fingers holding the insert and using my middle fingers to line up with the table cut out) turned on the saw, and moved the insert forward very slowly cutting the kerf. Quick, easy and works well. But I caution you, move slowly cause your thumbs are moving towards a blade. :)
- unclearthur
-- My "projects" always look better with beer goggles.
