Trouble getting a smooth finish on my walnut project. Please help!
Forum topic by HuntleyBill posted 974 days ago 1468 views 0 times favorited 12 replies Add to Favorites Watch
View HuntleyBill's profile
HuntleyBill
86 posts in 1257 days
974 days ago
The pictures show my walnut project i am trying to finish. What I’m shooting for is a gloss smooth as glass finish. I am using Arm-R-Seal oil and urathane wipe on finish. I have 5 coats on when I took these pictures.
I would apply 2 coats then wet sand with 320. I then put on 3 more coats sanding between with 800.
It is my understanding that a light sanding the “level” the surface should do it but as you can somewhat see in the first picture that it still looks pretty rough. Oh..keep reading…......
I then sanded some more and it started to look like I sanded through. ( at least I think I did ) The surface looked smooth but when I polished it with polishing compound ( just a small area to see what would happen) it didn’t seem to shine much at all.
This third picture is a shot showing what seems to be sanded through.
Did I sand through?
Can you sand through 5 coats of finish with 800 grit paper?
Can you help me with advise on what I may be doing wrong or how to get the finish I am looking for?
Maybe I just need 5 more coats????
Thank you all
-- If you think you can, or think you can't...your right!
12 replies so far
14847 posts in 2385 days
#1 posted 974 days ago
It’s hard to get a glass-smooth finish on walnut without using a grain filler.
It can be done like you are doing it. You actually need to sand more. The trick is that first you must build up the surface with 5 or 6 coats, then sand back with a coarser grit, like 220, until you have leveled the surface to the point that finish remains only in the grain. At that point, you will have created a smooth surface to build your final finish on.
This is very much a trial and error process. Sometimes I multiple-coat and sand back several times until I am satisfied.
View Lee Barker's profile
Lee Barker
1884 posts in 1017 days
#2 posted 974 days ago
Are you sanding with a block?
View PurpLev's profile
PurpLev
7730 posts in 1815 days
#3 posted 974 days ago
like charlie said – it seems like you need to fill in those grains as you have an uneven coat which prevents you from getting that glass smooth finish.
aside from that – since you are using wipe on finish, you’ll really need to build up coats before you can start sanding it down. thats why I like to start with brushing the first 2-3 coats to build up some film, then I move on to wiping so that each additional coat is thinner, dries faster, and spreads more evenly.
HuntleyBill
#4 posted 973 days ago
Thank you guys. I appreciate your feedback. I block sanded everything down with 220 wet and brushed on anther coat. It’s blotchy in some areas and I am assuming those are areas that either went through to wood or are just very thin. I’m guessing another couple of coats will clear that up.
Thank you again for your help.
View Ger21's profile
Ger21
594 posts in 1298 days
#5 posted 973 days ago
As Charlie said, glass smooth finishes on open pore woods usually is done with grain filler.
Using a wipe on finish isn’t doing you any favors, either, as it builds up very slowly. Don’t be surprised if you need 10-15 coats.
Also, you don’t need to wet sand between the coats. Just use a random orbit sander with 220 between coats, until all the pores are filled. At that point I’d put at least 3 more coats on, before final wet sanding and rubbing out.
-- Gerry, http://home.comcast.net/~cncwoodworker/CNC_Woodworker.html
View HoBoMoNK's profile
HoBoMoNK
1381 posts in 2294 days
#6 posted 973 days ago
When I want a smooth finish on walnut, I use a traditional pumice/oil grain filler, seal with shellac, then used multiple layers of oil-based varnish with wet sanding.
-- 温故知新
View Kindlingmaker's profile
Kindlingmaker
2646 posts in 1693 days
#7 posted 973 days ago
Here’s another vote, like Charlie said. From your photos you have pretty much filled and sealed now you have to sand to your glass like surface and apply your final coats.
View RichClark's profile
RichClark
157 posts in 1597 days
#8 posted 973 days ago
I would keep going but try this… Put down and keep your TOP wet with your Finish… while and as it is wet sand it with your 220 block.. You’ll make a swarf of your finish and the wood that will fill the pores.. work it “across” the grain…. to your packing in the swarf. Let it dry and then sand it across the grain again… repeat till you cannot see them big huge pores anymore as depressions in the surface. You could cheat and get there faster if you just fill them. Go buy some neutral wood filler and mix a bit of it with some stain you have on hand… (darker the better). Use a tight knit (like and old bed sheet) piece of fabric and working in small areas rub in circles (maybe 6” square area), until it starts to dry. Again pushing it across the grain as it gets harder.. and move on till the top is all equally rubbed up… let it dry and sand it across the grain till it is down to the wood again. then start your finish again… it should only take a a few coats and its glass. (your photo’s are perfect pictures of them Pores… It will take ya for ever to get ahead of them as far as filling them up, because your also making the walls making them higher).
Finish is = → sand → Fill → Stain → Protect Skip one and its lost.
Rich
-- Duct Tape is the Force! It has a light side and a dark side and it Binds the Universe together!
View Jim Crockett (USN Retired)'s profile
852 posts in 1900 days
#9 posted 973 days ago
If you take a look at my projects, you will note that I frequently use figured walnut for box tops. When I finish these tops, I will usually apply 5-6 coats of shellac (Armor Seal will work, just need to wait a lot longer for it to dry, like 1 week), then sand back to the bare wood. At this point if you hold the piece up to the light, you will see lots of shiny spots – these are the pores that still aren’t filled. Add another 5-6 coats, then sand back again. As you get close to sanding bare wood, check frequently. When the surface is a uniform dull sheen, you have filled all of the pores and leveled the surface. I should stress that you must use a sanding block to do this correctly.
Now that the pores are filled and the surface leveled, you can apply the finish of your choice and you should have a beautiful whatever.
If you want to find more information, Google “sand back” or “fill pores with shellac”.
Jim
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
#10 posted 973 days ago
I think the lesson here is that there are many possible ways to go. Any of the methods suggested here will work. I know I personally haven’t even scratched the surface (pardon the pun) when it comes to different finishing methods.
View AtomJack's profile
AtomJack
1279 posts in 1276 days
#11 posted 973 days ago
Grain filler seems like the least expensive and time consuming of finish methods for filling pores and such. I’ve built small projects by finishing and sanding; it’s easy when the project is small.
View FredG's profile
FredG
140 posts in 1864 days
#12 posted 973 days ago
Some videos on finishing wood with large pores.
In this case Mahogany
http://www.ehow.com/videos-on_4736_refinishing-wood-furniture.html
-- Fred
