Curved roofing
Forum topic by willhime posted 02-13-2017 12:20 AM 798 views 0 times favorited 8 replies Add to Favorites Watch
View willhime's profile
willhime
122 posts in 1717 days
02-13-2017 12:20 AM
Topic tags/keywords: question resource tip trick
I’m making a hobbit hole chicken coop for a friend and am kind of halted at my roofing approach. At first I considered overlapping lengthwise planks out of 1×6’s. But now I think I want to go traditional roofing shingles (the tar kind with adhesive backing). The problem is how to attach them. I was going to buy 5mm underlayment sheets and just tack them up along the curve but upon further research I found that the minimum requirement for roofing shingles is 18mm or .7”. There’s no way 3/4 plywood would even dare to be bent on that curve (I don’t think) without cutting relief dados. I then thought maybe running 1×4’s lengthwise might work but was hoping to avoid that method. Thoughts ?
-- Burn your fire for no witness
8 replies so far
willhime
#1 posted 02-13-2017 12:21 AM
(Sorry for the picture orientation… iPhone )
View wkndwrnch's profile
wkndwrnch
55 posts in 2547 days
#2 posted 02-13-2017 12:30 AM
How about multiple layers stacked together of 5mm plywood, or “wacky board” bending luan plywood,multiple layers.
View JCamp's profile
JCamp
850 posts in 728 days
#3 posted 02-13-2017 12:34 AM
I’d use 1/4 or 1/2 plywood Probably do two layers
-- Whatsoever thy hand findeth to do, do it with all thy might
runswithscissors
2874 posts in 2203 days
#4 posted 02-13-2017 05:14 AM
T & G 1X4s would work well. The interlocking feature would make the boards less bouncy when fastening the shingles. Even better if you used a roofing nail gun.
View Snipes's profile
Snipes
194 posts in 2422 days
#5 posted 02-13-2017 01:11 PM
well it’s hard to tell from the pic, but I think 1’2” ply would bend right around there. other wise use your 1×6 or 1×4 idea,(shiplap would be best) but will cost you much more. I’m not familiar with an adhesive back shingle. around here we use asphalt shingles, nail them down and they will stick down in the sun. You can also get steel for this roof.
-- if it is to be it is up to me
Craftsman on the lake
2823 posts in 3615 days
#6 posted 02-13-2017 03:54 PM
On a curve like that 1/8” plywood or paneling… whatever’s the right price will be fine. Just be sure to anchor it good to the braces at the edges. The arching effect will give it strength say.. if it should snow on it.
Smitty_Cabinetshop
15659 posts in 2796 days
#7 posted 02-13-2017 04:21 PM
- willhime
Turn your iphone so the home button is under your right thumb, then take / post pictures. They’ll be proper for LJs that way, no additional work needed.
View Lazyman's profile
Lazyman
2561 posts in 1565 days
#8 posted 02-13-2017 04:55 PM
You might want to look at some of the stuff on the web related to making teardrop campers. There are several techniques for forming the outside teardrop roof that might give you some ideas.
