Exterior decking finish
Forum topic by platinumaa posted 02-12-2017 09:05 PM 407 views 0 times favorited 6 replies Add to Favorites Watch
View platinumaa's profile
platinumaa
13 posts in 663 days
02-12-2017 09:05 PM
We are using 2×6x12 pt lumber for floor decking. The deck is approx. 8×60 feet long. The deck I put on my house a couple years ago I didnt finish.. but im building a deck for my daughters and they have log siding with “Cabots cordovan brown” stain color. Since the floor decking will have walking traffic, is it smart to stain? I assume the stain will wear off in the standard path from stairs to front door. if stain is common, please recommend what I can put on top of the cabots stain to protect the floor decking. Or if someone has another method/product instead of cabots
Thanks for the help!
View Gene Howe's profile
Gene Howe
10906 posts in 3576 days
#1 posted 02-12-2017 10:52 PM
Take a look at Sikkins. Good stuff and they have a wide range of browns.
We put it on our redwood deck and reapplied in two years. That application has lasted 5 years. Seems to be highly UV resistant, too.
View JCamp's profile
JCamp
819 posts in 698 days
#2 posted 02-13-2017 12:45 AM
You should b fine as long as you use quality stain and multiple coats. I’ve used the cheap stuff and it does not last. Visit ur local mom an pop shop. I personally don’t trust walmarts paints or stains. ACE hardware seems to be consistently good (at least for me).
-- Whatsoever thy hand findeth to do, do it with all thy might
platinumaa
#3 posted 02-13-2017 03:51 AM
if i stain it w/ the “Cabots cordovan brown”, is there something clear that i can put on top of it for additional durability? the cabots is whats on the logs now, i would want to match the decking to the logs
i read on the “sikkins”, its sold at home depot. it said “translucent finish”. i assume this would go over the cabots stain? i know the girls dont want a glossy finish, they would like a flat finish, hopefully thats available
thanks
Gene Howe
#4 posted 02-13-2017 05:13 PM
Sikkins has a less than semi gloss look at first. Not matte but not terribly shiny, either.
No matter what you protective coat you put over a stain, it’s going to alter the color, somewhat. So why not take a look at a Sikkins color chart to see if one is close to Cabot’s. Save a step.
JCamp
#5 posted 02-14-2017 05:09 PM
Whatever stain u choose just get a good quality stain and do multiple coats and restrain every year for several years. I’ve never personally used a sealer If you hav a sherwin williams around ur area u should visit it
platinumaa
#6 posted 03-02-2017 01:49 AM
perfect, thank you everyone for the input!
