Router question...
Forum topic by Mark posted 09-19-2010 02:07 AM 1109 views 0 times favorited 9 replies Add to Favorites Watch
View Mark's profile
Mark
1807 posts in 3176 days
09-19-2010 02:07 AM
Topic tags/keywords: router
So this is the router bit set I have just bought (which I’m so anxious to use) but my question about it is…
Do you have to use them on a router table? Why I’m asking is because I just tossed my old router table (piece of junk) and don’t currently have one so I was wondering if they’re good to go without the table. Thx a ton.
-- M.K.
9 replies so far
View GMman's profile
GMman
3902 posts in 3600 days
#1 posted 09-19-2010 02:09 AM
As far as I know Mark you need a table, I use one with my set of raised panel bits.
Can’t see how you can use then without a table.
View degoose's profile
degoose
7227 posts in 3257 days
#2 posted 09-19-2010 02:11 AM
Definitely not to be used hand held… Just make a new router table..
View Mark's profile
Mark
#3 posted 09-19-2010 02:13 AM
ya thats what I thought. Theres my next project I guess lol
-- M.K.
View Rick  Dennington's profile (online now)
Rick Dennington
5689 posts in 3097 days
#4 posted 09-19-2010 02:37 AM
Greetings Mark,
No…..never…...don’t try it…....bits are made for a table…...Dangerous…..Build a table…... Be safe…....
-- " Don't pet the sweaty things, and don't sweat the petty things."
View PurpLev's profile
PurpLev
8534 posts in 3551 days
#5 posted 09-19-2010 03:01 AM
If you want to use them as a weapon (mostly for self inflicting damage) you can use them freehand.
If you want to use them to make cabinet raised doors – use a router table.
FYI. depending on which set you bought (looks like an extra large panel raising bit 4”?) some router table inserts may not have a large enough opening for it. make sure if you are getting a plate that it’ll support the large bit.
TopamaxSurvivor
18189 posts in 3578 days
#6 posted 09-19-2010 08:12 AM
Boise, Looks like you need to have a table either way, hold the part or hold the router ;-))
View JimDaddyO's profile
JimDaddyO
533 posts in 2981 days
#7 posted 09-19-2010 12:34 PM
Nice set of bits! I would say for table use only too. I also think that the large raised panel bit would require a variable speed router to spin it at a lower speed. I would check if there is a rating on it.
-- my blog: http://watertoneworkshop.blogspot.ca/ my You Tube channel: https://www.youtube.com/channel/UCA5AretE3xPoVDV61AxUdUA?view_as=subscriber
View Uncle_Salty's profile
Uncle_Salty
183 posts in 2975 days
#8 posted 09-19-2010 01:52 PM
With the style and rail bits, plus the raised panel bits, you have made a fine purchase! Congrats! That said, to maintain both accuracy and safety, a router table will be necessary to assure both!
Store purchased router tables are great, as are the router table “wings” that can be installed in your table saw.
Heck… I have even seen wooden boxes used as router tables.
Your next concern is to make sure you have a router capable of using all three bits. The stile/rail bits should be okay with any 1 1/2 to 2 1/4 hp routers. But the panel bit? You’d better take some very shallow cuts, advancing the fence on your router table back not more than 1/4” until you get the desired profile on each side of the panel. If you have a 3+ hp router, you still have to ease your fence into the wood, but your router will be able to hog out some slightly deeper cuts.
View Ger21's profile
Ger21
1074 posts in 3033 days
#9 posted 09-19-2010 01:58 PM
You can easily use the Stile and Rail bits without a table, but you’ll need to make jigs, as the video shows.
But I’d definitely use a table for making raised panels. You’ll also need a variable speed router for the raised panel bit, as it should be spun at much lower rpm’s.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
