Kitchen cabinet problem. special joints? I don't want to have to do it over again.
Forum topic by ohtimberwolf posted 02-12-2017 05:29 PM 2685 views 0 times favorited 16 replies Add to Favorites Watch
View ohtimberwolf's profile
ohtimberwolf
862 posts in 2500 days
02-12-2017 05:29 PM
Topic tags/keywords: kitchen shaker cabinets white paint
Hey Kitchen Cabinet makers. When your wife wants your build to be shaker style and painted white how do you keep the paint from cracking as the wood moves?
My experience has been that painted wood cabinets don’t look so good after a while due to shrinking panels and so on. Or, is there a joint that will work better than others? Help.
Here is an example of the type doors I would be making.
-- Just a barn cat, now gone to cat heaven.
16 replies so far
View Kelster58's profile
Kelster58
670 posts in 688 days
#1 posted 02-12-2017 05:41 PM
I have found that spacers glued into the space between the panel and door stile and rail help with expansion and contraction. They keep the panel centered and tight during expansion and contraction. As the panel shrinks these things keep it centered so cracks between the panel and stile aren’t as noticeable. Keeps the panel still so it doesn’t rattle either. Here is a link to them on Amazon: https://www.amazon.com/gp/product/B0006LA198/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I agree completely with TungOil and RichTaylor…......Very good solutions.
-- K. Stone “Tell me and I forget, teach me and I may remember, involve me and I learn.” ― Benjamin Franklin
View Rich's profile (online now)
Rich
3667 posts in 738 days
#2 posted 02-12-2017 06:00 PM
Since they are going to be painted, I suggest using MDF for the panels. There will be no movement and its smooth surface is perfect for painting. I did that for some cabinets I put in at my old house, and they still looked great after 10 years. It’s much cheaper too.
Poplar works well for the rails and stiles. It’s very stable, mills cleanly, and is a great surface for paint.
I also second the recommendation for space balls. Even though there would be no expansion or contraction with MDF, they do keep the panel stable and rattle free.
View TungOil's profile
TungOil
1034 posts in 643 days
#3 posted 02-12-2017 06:01 PM
Paint the center panel before you assemble the door. Plywood panels will be more stable. You will probably still get a fine crack in the paint where the rail and stile meet but you can minimize this by using narrow rails and stiles.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View waho6o9's profile
waho6o9
8434 posts in 2725 days
#4 posted 02-12-2017 06:30 PM
MDO panels and as stated above, paint before you assemble them.
5097 posts in 2641 days
#5 posted 02-12-2017 06:47 PM
MDO (which paints nicely) or regular veneer plywood, or MDF panels. They don’t move in a measurable fashion. Glue them into the frames and you not only have a really solid door, but no movement problems.
ohtimberwolf
#6 posted 02-12-2017 08:01 PM
Thanks guys, great food for thought. I’ll surely do some if not all suggested. I have no experience with painting new cabinet work. larry
View Loren's profile
10477 posts in 3796 days
#7 posted 02-12-2017 08:03 PM
use plywood.
For stain grade I put a nail top and bottom
in th back of the door frame to keep the
panel centered.
I’ve used spaceballs too.
ohtimberwolf
#8 posted 02-12-2017 08:18 PM
Does anyone know if space ball will deteriorate over time?
View MT_Stringer's profile
MT_Stringer
3175 posts in 3379 days
#9 posted 02-12-2017 08:19 PM
You made me go look at our buffet that we built about 3 years ago. I don’t see anything that resembles movement. I used space balls in the drawer construction and poplar for the raised panel doors.
Example (dry fit).
Drawer fronts
Outdoor spray booth! (primer)
Finished project
Happy Camper
Rich
#10 posted 02-12-2017 08:40 PM
- ohtimberwolf
I’ve deteriorated over time, but the space balls are going strong.
Seriously though, I bought a bag of 1000 on Amazon a long time ago, and they are still the same.
ohtimberwolf
#11 posted 02-12-2017 09:56 PM
Stringer, looks great. What type of finish paint did you use. Did you use an airless sprayer?
Rich, sounds like you won’t be needing any more. Thanks for the info.
MT_Stringer
#12 posted 02-12-2017 10:11 PM
Rich, sounds like you won t be needing any more. Thanks for the info.
- ohtimberwolf
Latex paint using an airless sprayer. Then a friend applied a glaze and a clear finish over it.
ohtimberwolf
#13 posted 02-12-2017 10:21 PM
Thanks, this is new ground for me. Never liked risking painted kitchen cabinets. larry
View rwe2156's profile
rwe2156
3094 posts in 1629 days
#14 posted 02-13-2017 01:22 PM
Best to use ply to avoid movement issues, plus you can glue them in which makes the door stronger.
If you’re doing raised panes, I would use solid wood (I very much dislike milling MDF due to toxicity issues). Paint them before installing that way if they shrink a bit the border won’t show.
If you do them correctly the purpose of frame and panel is to allow the panel to move. I’ve never used space balls but they are a good idea.
I seriously doubt they will move enough to crack paint. Most paint is designed to be a bit elastic. I would use a high quality paint from a paint store they will advise you on the best type.
Standard construction for kitchen cab doors is cope and stick. Special router bits available. On wider doors you could consider mortise/tenon for strength to reduce tendency to warp or twist. I’ve built large pantry doors using cope and stick with no problems (plywood panels glued in).
The best advice I can give you is be VERY aware of wood moisture content/drying/acclimating, etc. Mill the wood incrementally don’t take more than 1/16” and do it everything evenly to both sides. Is you’re using surfaced wood, no problem just be aware even if the wood is kiln dried I recommend acclimating for at least a week after cutting to size.
View pontic's profile
pontic
634 posts in 757 days
#15 posted 02-13-2017 01:48 PM
I would spray them for sure. Prepaint the panels regardless, this will help keep glue squeezeout from sticking the panel to the frame. When the panel frame is plywood and one corner is glued to the rail/style glue joint, it can (and did to me) pull the veneer surface from the substrate of the panel. Prefinishing or prepainting the panel will greatly help to avoid this.
-- Illigitimii non carburundum sum
