Would this be an ok setup for a DC system - adding a seperator
Forum topic by thomasfurman posted 02-12-2017 05:01 PM 564 views 0 times favorited 9 replies Add to Favorites Watch
View thomasfurman's profile
thomasfurman
22 posts in 550 days
02-12-2017 05:01 PM
Just got a big boy dust collector. I’d like to add a separator “cyclone” so I don’t have to empty the bag or unclog the impeller. I picked up a nice locking 30g drum.
I’ve seen many people modify the DC so the motor is mounted higher (on 2×4) and the drum sits beneath. I’m not to keen on modifying my new stuff to that degree. Would it be ok, or would it ruin the CFMs if I build a little stand and place the drum above the motor?
I attached a little drawing to show what I so poorly described.
9 replies so far
5015 posts in 2546 days
#1 posted 02-12-2017 06:53 PM
What you want to do will work just fine. The downside might be there are more elbows for the air to negotiate which increases drag on the flow, and if that’s all flex hose it will increase significantly.
View TheFridge's profile
TheFridge
9708 posts in 1539 days
#2 posted 02-12-2017 07:06 PM
Ditto
thomasfurman
#3 posted 02-12-2017 07:48 PM
What you want to do will work just fine. The downside might be there are more elbows for the air to negotiate which increases drag on the flow, and if that s all flex hose it will increase significantly.
- Fred Hargis
that’s what I was assuming…poop…maybe ill try it and see!
Shawn Masterson
1325 posts in 2001 days
#4 posted 02-12-2017 08:11 PM
Here is a link to my system. It’s very similar to what you are trying to do, and works great. It does fill up pretty fast when planeing. for your setup I would hang the motor over the 30 gallon bin. that would shorten up the pipe and loose some elbows. http://lumberjocks.com/topics/49759
View jimintx's profile
jimintx
804 posts in 1637 days
#5 posted 02-16-2017 05:29 PM
I suggest you build it exactly as you want, and see how it works. Our internet guesswork will not beat the accuracy and usefulness from an actual test of the system.
When you do, think of every step you can to minimize the drag on air flow. Maybe use 6” hard lines to connect from your drum to your blower motor suction. Come out of the side of the 30g drum, up high near the top, rather than straight up out of the top, so an elbow is eliminated. Use 45-degree bends when possible, instead of 90-deg. And so on.
I believe this question is about reducing internal drag, not about any pressure differentials that might result simply from the drum being higher above the motor. I bet that almost every DC system in use could be redone to cut some of the internal drag. If you make sure your whole system is well designed, the effect off this plan for drum placement should be negligent, and maybe none.
-- Jim, Houston, TX
View sawdustdad's profile
sawdustdad
364 posts in 938 days
#6 posted 02-16-2017 06:51 PM
My only comment is handling the drum full of chips that is a few feet off the floor. I’d just set the drum on the floor next to the blower. That way you can hand truck it out without risk of dropping it on your foot!
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View pintodeluxe's profile
pintodeluxe
5725 posts in 2866 days
#7 posted 02-16-2017 06:56 PM
1-1/2 hp minimum motor requirement to add a separator. 2hp would be better.
Fan diameter and duct layout has a great deal to do with the final performance of the system. The 14-15” fans do a pretty good job at generating CFM. 4” trunk lines and flex hose do a pretty good job of killing CFM.
sawdustdad
#8 posted 02-16-2017 07:31 PM
One more comment. I put my 30 gal separator right next to my planer. That way, you’re not pulling all those chips all the way to the blower. My planer is about 30 feet from my DC.
jimintx
#9 posted 02-16-2017 08:08 PM
One more comment. I put my 30 gal separator right next to my planer. That way, you re not pulling all those chips all the way to the blower. ...
- sawdustdad
Very good point.
-- Jim, Houston, TX
