Millers Falls no 5 restoration questions
« back to Hand Tools forum
Forum topic by simoncpj posted 02-11-2017 04:53 PM 578 views 0 times favorited 2 replies Add to Favorites Watch
View simoncpj's profile
simoncpj
23 posts in 659 days
02-11-2017 04:53 PM
Hi all, I am undertaking a restoration of a Millers Falls no 5 hand drill and was hoping for some advice in two areas.
First, the threaded handle cap is loose. There is a hairline crack that I intend to inject some CA glue into to repair that but don’t think it will fully snug up the handle as the treads have seen some good use. I was thinking of wetting the threaded area on both the handle and cap to try to swell the threaded area. Is that wise or is there a better way?
Next much more mundane question, anyone know the correct size of the screw that holds the crank onto the gear wheel?
Thanks
2 replies so far
View Tim Dahn's profile
Tim Dahn
1568 posts in 3712 days
#1 posted 02-12-2017 01:56 AM
Is the crack in the cap? I would (with rubber gloves) work some epoxy in the crack then clamp while drying.
Not sure on the screw, 6-32 or 8-32? You could take it with you the the Hardware store to find one that fits.
View BurlyBob's profile
BurlyBob
5918 posts in 2413 days
#2 posted 02-12-2017 04:27 AM
I suggest you check out, WK fine tools.com He’s got quite a section about restoring Miller Falls hand drills.
