Sketchup output into Enroute
Forum topic by wwbob posted 09-18-2010 07:29 AM 2375 views 0 times favorited 4 replies Add to Favorites Watch
View wwbob's profile
111 posts in 2806 days
09-18-2010 07:29 AM
Topic tags/keywords: question
I’ve used Sketchup to design a plywood based project. Since I have the free version of Sketchup, I can not output the design in a “standard” format, so I can not test what I’m asking about. I have to take the measurements from Sketchup and re-entered the design into the CAD tool Enroute by hand. I use Enroute then to drive the automated router to cut the design out of plywood.
Has anybody made an automated connection of Sketchup to Enroute? If yes how well does it work? Is it worth the $495 that the pro version of Sketchup costs.
-- "I like the quiet I hear." - Channing, age 4
View daltxguy's profile
1373 posts in 3845 days
#1 posted 09-18-2010 09:56 AM
I’m not familiar with enroute, but if you use my Cutlist plugin for sketchup, you can at least generate a csv of all of the part dimensions. Would that help?
My plugin is described here
-- If you can't joint it, bead it!
#2 posted 09-18-2010 05:27 PM
The Cutlist plugin is a good addition to sketchup. I have not tried on the current design as there are very few straight lines to be cut. Lots of arcs. That’s the reason I’m using the automated router. Once I get one finished I’ll post a picture.
Thanks for the suggestion.
View dedov's profile
14 posts in 3129 days
#3 posted 09-19-2010 08:29 AM
View Ger21's profile
1074 posts in 3062 days
#4 posted 09-19-2010 03:08 PM
