narrow table support design
Forum topic by Karda posted 02-11-2017 07:44 AM 466 views 0 times favorited 8 replies Add to Favorites Watch
View Karda's profile
Karda
1178 posts in 639 days
02-11-2017 07:44 AM
Hi I have a 13” x 43” table top I built out of 2×4s and planks. the top will be heavy but narrow. What woulf b a good way to support this. I am going to use it for a small wood lathe. the lathe weighs 80 pound. Any suggestions
8 replies so far
View CaptainSkully's profile
CaptainSkully
1601 posts in 3643 days
#1 posted 02-11-2017 05:57 PM
If your aprons are 2×4’s are on edge, you shouldn’t need any additional support for that size/weight.
-- You can't control the wind, but you can trim your sails
View William Shelley's profile
William Shelley
576 posts in 1554 days
#2 posted 02-11-2017 06:00 PM
If you’re asking about the legs, I would say make them splayed out a bit like a sawhorse because otherwise the whole thing might be a bit tippy.
-- Woodworking from an engineer's perspective
Karda
#3 posted 02-11-2017 07:26 PM
ok thanks
View ArtMann's profile
ArtMann
1009 posts in 901 days
#4 posted 02-12-2017 02:07 AM
I don’t think your table will be stable unless you tie it to a wall. It is just too narrow. You can either put legs on it and shove it against the wall or actually mount the table to the wall without any legs if the situation allows it.
Karda
#5 posted 02-12-2017 02:44 AM
I was wondering if I could use the wall, it is block with a block beam support creating a corner. how would you tie into a block wall
View Mike_D_S's profile
Mike_D_S
482 posts in 2299 days
#6 posted 02-12-2017 09:11 PM
A picture would help, but if it’s masonry block, using Tapcon screws to attache some mounting blocks to the wall should let you tie the table to the wall fairly simply.
Also, I wouldn’t go without legs. During normal use a lathe will have vibrations and you don’t want to end up with some kind of failure later where the whole assembly falls of the wall.
Tied to the wall, you shouldn’t have to splay the legs. Also, you can enclose the legs as storage at some point in the future.
Mike
-- No honey, that's not new, I've had that forever......
View mrbob's profile
mrbob
182 posts in 654 days
#7 posted 02-12-2017 09:46 PM
Legs with feet like this, you can extend the feet, make them longer then the bench is wide, for added stability.
Karda
#8 posted 02-12-2017 10:04 PM
thanks that gives me a lot to think about, I could use feet up to 2 feet long. I like the design of the work bench you posted that is an idea. here is a picture of where I want to ut it.
