| Forum topic by GabrielX | posted 978 days ago | 3053 views | 0 times favorited | 6 replies | ![]() |
978 days ago |
Topic tags/keywords: shed garage storage outdoor outside tool shed tool storage tractor storage lawnmower shed barn shop outside shop detached shed Anyone know where I might find some good plans or dimensions/parts list for a decent 9X10, 9X11, 9X12, 9X13, 9X14 shed?? -- GX |
#1 posted 977 days ago |
Jenn and I have been mulling over the idea of building a ‘snowblower/lawnmover seasonal yard tools type shed (to get these out of my shop…uhh garage). I don’t think it would be too difficult to draft one up yourself, that is what I intend to do once I get a little bit of time. -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#2 posted 976 days ago |
When I built my shed I got a book on storage shed from the reference book section at Lowes. It was a helpful guide to get the project started. I built a 10×12, and that has turned out to be a decent size for our lawn and garden equipment. |
#3 posted 976 days ago |
You can find plans for sheds at Menards and I’m sure the other box stores, but may I suggest buying pre made trusses insted of building them, makes the build faster and I think the cost of the trusses vurses the time to build them is a push. -- Charlie............Only time will tell if it was time well spent. |
#4 posted 976 days ago |
Charlie’s right about pre-made trusses the cost to self-build is minimal and time saved is great as for plans make your own you decide were you want stuff just remember its just a box http://www.selfstorage-london.com/Free_Storage_Shed_Plans.htm try is site Andy -- cut it saw it scrap it SKPE: ANDREW.CARTER69 |
#5 posted 976 days ago |
Why 9 feet as a base dimension? Nothing wrong with it but it seems to be a waste of materials or the use of a lot of little pieces. A standard shed, especially as narrow as 9 or 10 feet is a simple rafter and joist system. Trusses are expensive and rafters are cheap common material and easy to cut once a pattern is made. Don’t forget the birds-mouth to lock the top plate and use joists to keep the walls from pushing out. You’ll be fine and the money saved can push the dimension out a little. Linear feet are cheap because you have to build the end walls anyway. Go as big as you can, you’ll be glad you did when it starts filling up. -- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch) |
#6 posted 976 days ago |
+1 on building your rafters. I was nervous about that when I started, but like BTKS points out, once you decide on the pitch of your roof, using a Swanson framing square will get you through the rafter portion. Mine was a fun learning experience and it is in the end just building a big box. I went 5/12 on my roof and that worked well for my shed. Once you mark and test fit one rafter pair then use one of them and mark all your others for consistency. I used 1x wood for my ridge board and held it in place with a 2×4 until the rafters and plywood tied everything together. |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15786 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
