Sawdust + glue as a filler.
Forum topic by Carloz posted 02-09-2017 08:07 PM 1203 views 0 times favorited 17 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 712 days
02-09-2017 08:07 PM
Practically everyone says do it. I tried with titebond and got disastrous results. Stain lays very differently in such “filler” creating unsightly spots. Maybe I should use different glue ?
17 replies so far
View mrbob's profile
mrbob
182 posts in 690 days
#1 posted 02-09-2017 08:15 PM
Tite Bond makes a colored glue, drys about the shade of Cherry.
View jerryminer's profile
jerryminer
944 posts in 1562 days
#2 posted 02-09-2017 08:36 PM
Yeah—doesn’t work well for stained projects. Better for clear finishes.
View Madmark2's profile
Madmark2
388 posts in 709 days
#3 posted 02-09-2017 08:41 PM
Sawdust is all endgrain. If it absorbs glue, it can’t absorb stain. Sawdust & glue seems like a good idea, it ain’t.
M
5072 posts in 2614 days
#4 posted 02-09-2017 09:18 PM
It’s never worked to my satisfaction.
View Kazooman's profile
Kazooman
1117 posts in 2073 days
#5 posted 02-09-2017 09:22 PM
Have you ever stained a piece where there was some glue squeeze out that you missed? Stain doesn’t penetrate glue. There may well be some type of filler that takes stain like the surrounding wood, but I am not aware of any. Same goes for penetrating finishes like oils. They won’t penetrate the glue. Timber mate makes a great filler, but you can’t have big gobs of it on a piece and hope for great results. I have advocated the sawdust and glue filler on many occasions. That said, I would only use it to fill a small imperfection like a tear out in a dove tail, and I haven’t stained a project for a long time.
You might get better results if you apply a sealer before the stain. That might help even things out.
View alittleoff's profile
alittleoff
541 posts in 1397 days
#6 posted 02-09-2017 11:45 PM
A small Crack or seam can be filled with sawdus. I use it sometimes if the Crack or seam is SMALL only. You can try using titebond Hide Glue. It takes a stain. To a degree.
Gerald
View Rich Simon's profile
Rich Simon
25 posts in 1487 days
#7 posted 02-10-2017 12:04 AM
I keep hide glue for just this purpose and it works well. Dries clear. Admit though I can’t recall quality of staining over it vs surrounding.
View shipwright's profile
shipwright
8070 posts in 2919 days
#8 posted 02-10-2017 12:35 AM
Hide glue and fine sanding dust is the standard for french marquetry filling.
Hide glue and sawdust would work better than any pva of course because it doesn’t block insides and it dries hard enough to sand well.
View rwe2156's profile
rwe2156
3073 posts in 1602 days
#9 posted 02-10-2017 12:52 AM
Tight joints eliminates the need for filler ;-)
I try to fill small gaps with a small wedge of wood rather than filler. The glue doesn’t matter in that case.
View Jack Lewis's profile
Jack Lewis
320 posts in 1199 days
#10 posted 02-10-2017 04:17 AM
In woodturning I use almost exclusively CA and very fine saw dust. I sift sawdust into dark, light and mixed shades to better match the area I am repairing. I use a tea strainer to sift into storage containers and mark the contents.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View Jim Finn's profile
Jim Finn
2670 posts in 3043 days
#11 posted 02-10-2017 01:35 PM
I do this often when doing inlays. Best if only used in very small voids. Sawdust is too coarse for this, so I only use sanding powder from my random orbital sander mixed with white glue. It will not take stain nor finish all that well. Titebond Liquid Hide glue will take clear finish well. It does darken the filler a bit though.
-- No PHD just a DD214 Website> craftingcouple.com
runswithscissors
2823 posts in 2146 days
#12 posted 02-11-2017 09:38 PM
Epoxy with fine sanding dust works very well. Will take stain, but will be darker than the base wood. 5 minute epoxy works fine. I like to buy it in 4 oz. bottles, as it is much more economical than the little tubes.
View jeffswildwood's profile
jeffswildwood
3486 posts in 2098 days
#13 posted 02-11-2017 09:50 PM
Stain will not adhere to titebond. Just a residue on your project will not stain. So mixing with sawdust gets the same results. I have had luck with old elmers though.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View Matt's profile
Matt
160 posts in 1072 days
#14 posted 02-12-2017 12:40 AM
I’ve done it, and it works great when the finish is and enamel paint.
-- My "projects" always look better with beer goggles.
View youdidntbuildthat72's profile
youdidntbuildthat72
18 posts in 642 days
#15 posted 02-14-2017 10:03 PM
What if you stained the sawdust first then use clear glue to fill the crack or gap? would that work better than using sawdust and glue and then trying to stain it?
