Finding a double back tape that leaves no residue
Forum topic by scjetson posted 02-09-2017 06:58 PM 1536 views 2 times favorited 12 replies Add to Favorites Watch
View scjetson's profile
scjetson
13 posts in 728 days
02-09-2017 06:58 PM
I use double back tape to join templates to wood for my bandsaw to follow. The problem is the tape I have been using leaves a gummy residue when removed. It is a real pain to get it off prior to finishing. Does anyone have a tape brand that they have used with no residue when pulled off?
Thanks! Jon
12 replies so far
View bondogaposis's profile
bondogaposis
4715 posts in 2344 days
#1 posted 02-09-2017 07:10 PM
Double sided tapes are highly variable in their performance. This is the one I like the best, I have had no problems with it ever.
-- Bondo Gaposis
View Rich's profile (online now)
Rich
2790 posts in 582 days
#2 posted 02-09-2017 07:24 PM
This is probably a similar product as the one Bondo linked to. It’s insanely sticky, but it does not leave a residue.
https://www.amazon.com/gp/product/B01B25SZI0
Tip: If you do buy it, you must tear off pieces rather than cut them with scissors. The scissors will seal the edge so tightly that you cannot get the top sheet off to expose the top adhesive surface. I only learned this after watching a video on the manufacturer’s site.
-- No matter how much you push the envelope, it'll still be stationery.
View papadan's profile
papadan
3584 posts in 3361 days
#3 posted 02-09-2017 08:23 PM
Use turners tape, strong enough to hold wood on a lathe but releases easy and no residue. I get mine from woodcraft.
View SuperCubber's profile
SuperCubber
1025 posts in 2277 days
#4 posted 02-09-2017 10:26 PM
Here is what I use:
https://www.woodcraft.com/products/double-sided-tape-1-x-36-yards
Sticks like crazy, no residue.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
Rich
#5 posted 02-09-2017 11:03 PM
Here is what I use:
- SuperCubber
$20 for a 36 yd roll of double sided tape is insane. They sell that at my Woodcraft too. If that’s all you have access too, I guess you have no choice, but instead, I go down to the PGA Superstore and buy narrow grip tape, which is the same thing, for $7.
I had assumed Jon’s original post was referring to plain old double sided tape like that. Now that I look back, that might not have been a correct assumption, since he doesn’t mention what he’s using that leaves residue.
Edit: I wasn’t calling you insane, BTW. It’s Woodcraft. I mean, it’s double sided masking tape, and $20 for a roll is highway robbery.
SuperCubber
#6 posted 02-10-2017 12:14 AM
No problem, I know what you mean. When I bought it was on sale. I think it was $10-12. Not cheap by any means, but it was the only place I could find it. I lasts forever though. I’m still on the original roll I bought several years ago.
View mahdee's profile
mahdee
3883 posts in 1760 days
#7 posted 02-10-2017 01:19 AM
I use carpet tape. As mentioned above, use box cutter blade to cut it not scissors.
-- earthartandfoods.com
View Nubsnstubs's profile
Nubsnstubs
1286 posts in 1723 days
#8 posted 02-10-2017 02:53 AM
Here is what I use:
- SuperCubber
$20 for a 36 yd roll of double sided tape is insane. They sell that at my Woodcraft too. If that s all you have access too, I guess you have no choice, but instead, I go down to the PGA Superstore and buy narrow grip tape, which is the same thing, for $7.
I had assumed Jon s original post was referring to plain old double sided tape like that. Now that I look back, that might not have been a correct assumption, since he doesn t mention what he s using that leaves residue.
Edit: I wasn t calling you insane, BTW. It s Woodcraft. I mean, it s double sided masking tape, and $20 for a roll is highway robbery.
- RichTaylor
At 18 cents a foot Woodcraft has a pretty good price if it holds. 3M tape with the plaid look on the roll is probably the best out there, but it’s a bit more costly. You won’t get any movement between the pieces you’re trying to duplicate. Carpet tape is pure trash for woodworking if you are serious about accuracy….. . Jerry (in Tucson)
View jbay's profile
jbay
2267 posts in 892 days
#9 posted 02-10-2017 03:03 AM
This is the best I have found. You will throw carpet tape away. lol
I pay 26.33 for a 200’ roll
Rich
#10 posted 02-10-2017 03:08 AM
At 18 cents a foot Woodcraft has a pretty good price if it holds. 3M tape with the plaid look on the roll is probably the best out there, but it s a bit more costly. You won t get any movement between the pieces you re trying to duplicate. Carpet tape is pure trash for woodworking if you are serious about accuracy….. . Jerry (in Tucson)
- Nubsnstubs
Yes, but 6 cents is better :)
I’ve had a good experience with the product I posted a link to. It sticks rock solid, so accuracy wouldn’t be a problem. I use it for things I need that strength for. The problem with it is getting the parts separated. If it’s holding a template for flush router bit trimming, it’s a bear.
The grip tape works for me. It holds tight and releases reasonably easily. I use lots of it. In fact I just bought three rolls last weekend at the PGA Superstore.
Rich (in Tucson, too)
scjetson
#11 posted 02-10-2017 03:49 PM
Thank you all for the excellent feedback and choices! Jon
papadan
#12 posted 02-10-2017 06:57 PM
The woodcraft tape will hold a square block of hard wood 8X8X4onto a lathe faceplate form start to finish of a bowl. You can’t pull it apart, you have to slide a putty knife in between the two pieces and they will come right apart. The tape will peel off the wood and leave no residue. Yes it is a little expensive, but so is your time to clean up the mess the cheaper tapes make. A little goes a long way. I use 1” and 3” wide depending on my project.
