Starting with Hand Planes... New or Used?
Forum topic by nordichomey posted 09-17-2010 03:30 AM 3240 views 1 time favorited 17 replies Add to Favorites Watch
View nordichomey's profile
nordichomey
100 posts in 3098 days
09-17-2010 03:30 AM
All my wood working in the past has been power tools. However, I have an increased desire to start using more hand tools. I have been looking to start with a #4 bench plane. For a beginner where do you start? New or used? There are a ton of planes of varying quality on ebay. My thought is to start with a good quality used plane versus a cheap new plane.
For the hand plane experts out there… what are your thoughts?
-- nordichomey
17 replies so far
View swirt's profile
swirt
2733 posts in 2968 days
#1 posted 09-17-2010 03:56 AM
Yes I suggest going better used than cheaper new. A much better investment if you don’t mind doing a little homework and a little restoration. Newer cheap will likely require more work anyway.
View DrewM's profile
DrewM
176 posts in 2995 days
#2 posted 09-17-2010 03:59 AM
Older stanley planes found on ebay are the way to go. With a little work and some sharpening they work great. Here is a great website for dating stanley planes. Try to find a stanley type 10 – 15 (1907-1932) they are my favorite “user” planes. Good luck, they are addicting to find, restore, and use.
-- Drew, Delaware
View Canadian Woodworks's profile
Canadian Woodworks
702 posts in 3066 days
#3 posted 09-17-2010 04:08 AM
I’m also new to hand planes, and I took the approach of saving for a Veritas plane from Lee Valley because I wanted a plane that need no work other then honing.
5 months later i’ve honed a few more times, and it’s still working as good as a plane can work, plan to have the plane for life, buy a plane you’d want to have for life.
I now have a bevel up smoother, low angle block plane, medium and large shoulder planes
All top notch, exceeds my expectations every time, always have a smile on my face when ever I use one.
-- Paul Lemiski, Ontario Canada, Custom Wooden Rocking chairs and tables http://www.canadianwoodworks.com
View PurpLev's profile
PurpLev
8535 posts in 3644 days
#4 posted 09-17-2010 04:31 AM
my vote is go with a used – take it apart, and through tuning and setting it up – you’ll learn more about it then any other way.
curious though, why do you want to start with a #4 though?
I’d start with either a block plane, or a #5 or bigger – something that can be useful to mill lumber or in the case of the block plane – be the most useful tool in the bunch.
View crank49's profile
crank49
4030 posts in 2967 days
#5 posted 09-17-2010 06:39 AM
Like PurpLev said, why do you want to start with a #4 ?
The way these bench planes work is:
- #5, 14” long, jack plane, with a slightly crowned iron, to hog off material fast. With a flat iron can smooth.
- #6, 18” long, fore plane, is better to take down the high spots. Extra length gives more even surface.
You can get by with either #5 or #6 if you must limit your choices for your first plane.
- #4, 10” long, smoothing plane. It removes the tool marks left by the #5 or #6. It would take too long to prep a board using only the smoothing plane. It only takes tissue thin shavings off when properly honed and set.
- #60 1/2, 6” to 7” long, block plane. A good low angle block plane is for working end grain.
- #7 or #8, 22” or 24” long, jointer plane. These are heavy, long planes for jointing edges straight.
If I was limited to only two planes, I’d want a #60 1/2 block, and a #5 jack with two irons (crowned & flat)
In a pinch, if I could start with three planes, I’d have a #60 1/2 block, a #6 fore, and a #4 smooth.
If I could have four planes, I’d probably have a #60 1/2 block, a # 7 jointer, a #5 jack, and a #4 smooth.
TopamaxSurvivor
18268 posts in 3672 days
#6 posted 09-17-2010 08:14 AM
Yesterday, I saw 3 or 4 nice Stanleys and a Miller sell on ebay for under $20!! I would have bid, but I already have some.
View richgreer's profile
richgreer
4541 posts in 3070 days
#7 posted 09-17-2010 03:11 PM
I have also developed an interest in hand planes recently. My strategy is to buy several cheaper used planes for the purpose of learning. Then I’ll buy some better planes when I better understand what I want.
View TheDane's profile
TheDane
5423 posts in 3659 days
#8 posted 09-17-2010 03:21 PM
I started out with an old Stanley #5 that I inherited from my Dad. I then picked up vintage Stanley and Craftsman planes at garage sales and on eBay. I didn’t buy a new plane (Veritas apron plane) until I had a pretty good sense of how to use and care for a plane.
BTW, my older Stanley planes (#3, #4, #5, and #7) were all retrofitted with Hock blades and chip breakers.
View helluvawreck's profile
helluvawreck
31056 posts in 2863 days
#9 posted 09-17-2010 03:24 PM
If I was you I would go the used rout. Take a look at Ebay. Buy some that are at least 50 to 75 years old. I think that it is better to buy them from somebody on Ebay that’s got a good track record. I have purchased over 400 items on Ebay and have been dissatified only once. I will admit that I haven’t bought anything in two years but I know others who have. I know that I have bought at least 10 or 12 planes. I would especially like to have a #8 stanley and also a stanley carriage makers plane or some people call it a bench rabbit. Good luck!!!.
View 8iowa's profile
8iowa
1580 posts in 3757 days
#10 posted 09-17-2010 03:37 PM
I started with a #5 Clifton, purchased from Highland Woodworking. It was $300 but beautiful beyond expectations, and was “ready to go” out of the box. For me, this was a necessary “jump start” on the learning curve.
Since then I have purchased several #’s 4, 5 and 6 at antique shops. I like to look for hand planes with adjustable frogs. Depending on condition, restoring, de-rusting, and tuning used hand planes can be time consuming and tedious.
Chris Schwarz, editor of “Popular Woodworking” has an excellent new book out, “Handplane Essentials”. I recommend it highly.
View dbhost's profile
dbhost
5710 posts in 3228 days
#11 posted 09-17-2010 03:52 PM
IF you have the time, and patience to restore an antique hand plane, pre WW2 Stanley planes are well worth the effort.
Having said that, I opted for new Groz planes, and yes I did have a LOT of tuning to do to them. I have a low angle block, a #4, and a #5, and they all work exceptionally well, but it took a bit of work to get them where I wanted them… In the long run, an antique will hold value better, but I wanted users, not collectors pieces…
View paratrooper34's profile
paratrooper34
915 posts in 2948 days
#12 posted 09-17-2010 08:59 PM
Here is what I did to get into planes:
I bought used ones off Ebay. I read books about planes and learned how to tune them up. I took that knowledge and tuned my planes for optimum use. What I found was the older Record planes I bought are great users once they were given the proper attention. I validated that train of thought when I used a couple of Veritas and LNs this week. My old Records worked just as good as those. True, the LNs and Veritas’ didn’t need tune up, but I saved a pile of money with the Records. Those savings bought some quality saws and chisels and such. Bottom line: buy some quality used ones, learn how they work, tune them up and you will have great planes you can use and save some money on they way.
-- Mike
View Richard Dunlap's profile
Richard Dunlap
65 posts in 2861 days
#13 posted 09-17-2010 09:47 PM
I have several Stanley planes that I found on e-bay. 2 #4, #5, #7, # 9 1/2 and a #60 1/2. Each for less than $40 including shipping, except for the #7, that one is heavy so shipping was more. They are all in good shape and all were made in the 30’s and 40’s. I love them.
Richard
View bunkie's profile
bunkie
412 posts in 3143 days
#14 posted 09-17-2010 10:01 PM
You could do what I did: Marry a woman who buys you a #4 Lie Nielsen bronze smoothing plane. My then-fiance surprised me with it for my birthday. The downside to this approach is that it only works once…
-- Altruism is, ultimately, self-serving
View knotscott's profile
knotscott
8009 posts in 3372 days
#15 posted 09-17-2010 10:06 PM
My sentiments exactly.
