kitchen countertop finishing question
Forum topic by platinumaa posted 02-09-2017 01:48 PM 649 views 0 times favorited 14 replies Add to Favorites Watch
View platinumaa's profile
platinumaa
13 posts in 572 days
02-09-2017 01:48 PM
I am in the process of building a house for my daughters (duplex style) and they purchased ikea butcher block for the kitchen countertops. But, I assume since these are in the kitchen that the butcher block has to be finished in a certain way to make them food grade capable.
Does anyone have a product and also a method to recommend to properly finish the cabinets for food grade? I know they don’t want to have a real shiny finish like you would see at a restaurant dining table. One daughter wants it stained kind of dark and the other wants it clear.
Any suggestions of products to use and method would be appreciated!
thanks
14 replies so far
View rwe2156's profile
rwe2156
3005 posts in 1538 days
#1 posted 02-09-2017 01:55 PM
There are food save finishes available. Mr. Google will help you there.
I’ve also heard people use mineral oil and beeswax.
View Rich's profile
Rich
3209 posts in 646 days
#2 posted 02-09-2017 02:26 PM
Just about any finish is food safe once it’s cured. If you want a durable, attractive, easy-to-apply finish, it’s hard to beat wipe-on poly. You can get it in satin, and just keep adding coats until you get your desired surface.
It’ll be a few weeks before it’s cured to the point where you can’t detect any odor.
Oils and wax are not going to be durable in the long run.
117160 posts in 3634 days
#3 posted 02-09-2017 02:29 PM
I agree with Rich
platinumaa
#4 posted 02-09-2017 03:47 PM
rich, thanks for the info.. the ‘wipe on poly”, does it have that real shiny finish when its complete? the girls dont like that thick shiny finish, also do you have a brand you like?.. thanks for the info!
RWE, i am aware google has that info, almost 5 million pages in .02 seconds.. but i like forums since i can give detailed questions and get specific answers
thanks again!
View smitdog's profile
smitdog
372 posts in 2162 days
#5 posted 02-09-2017 03:57 PM
You can get poly in different sheens, gloss, satin and I think there is even a matte available. The higher gloss is more durable because it has more of the hardening agent in it so what I did on my floors was several coats of the gloss for durability then a couple coats of satin on top to knock the shininess down. But for countertops you could go all matte and be fine, no feet stomping around on it and all… The wipe on poly has more of a satin look to it as well, definitely nothing like the high gloss epoxy bar top coatings and restaurant tables.
-- Jarrett - Mount Vernon, Ohio
View CharlesNeil's profile (online now)
CharlesNeil
2422 posts in 3928 days
#6 posted 02-09-2017 04:04 PM
For whats is worth I am, as we speak, finishing up some Walnut counter tops, and I will be doing as smitdog said, I am going with base coats of gloss and then finish in satin, I am using Arm R Seal .
View Rich's profile
Rich
#7 posted 02-09-2017 04:14 PM
rich, thanks for the info.. the wipe on poly”, does it have that real shiny finish when its complete? the girls dont like that thick shiny finish, also do you have a brand you like?.. thanks for the info!
- platinumaa
You can get wipe-on poly in gloss or satin. You said they didn’t want a shiny surface in your original post, so that’s why I mentioned satin in my reply.
platinumaa
#8 posted 02-12-2017 08:58 PM
perfect, thank you everyone for the knowledge.. i appreciate it!
View WoodMac56's profile
WoodMac56
3 posts in 485 days
#9 posted 03-25-2017 11:44 AM
Agree on the Arm-r-seal. I built walnut counters and initially used Waterlox but it scratches way too easy. Top coated with arm-r-seal and it is much more durable.
View Carloz's profile
Carloz
1147 posts in 648 days
#10 posted 03-25-2017 04:21 PM
You guys must be messing with the OP. What kind of fool would put a polyurethane on a kitchen countertop that is subject to standing water, oils, cleaning supplies, some hard actions from utensils, hot frying pans and pots, etc etc.
Countertops must be finished with oils and other non-curing finishes and reapplied regularly.
View Rich's profile
Rich
#11 posted 03-25-2017 11:00 PM
- Carloz
What kind of fool thinks that any topcoat for a wooden countertop would resist damage from a hot frying pan?
View MrUnix's profile
MrUnix
6830 posts in 2256 days
#12 posted 03-25-2017 11:08 PM
- Carloz
Yeah… that polyurethane stuff is only good for floors where it won’t see any abuse :)
View JBrow's profile
JBrow
1365 posts in 977 days
#13 posted 03-26-2017 03:31 PM
Platinumaa,
Evidently your daughters have differing tastes and I am sure you want to keep piece in the family. I assume the butcher block countertops will require some trimming to fit. If so, a couple of offcuts could be used as sample boards. Various stains and finishes could then be applied along the length of the offcuts. Perhaps among the array of choices displayed on the offcuts to which the test finishes were applied, your daughters could settle on a look that they both like. Hopefully whatever they decide, the final look of the installed countertops will work well with the woods and color tones in the rest of the kitchen.
View patcollins's profile
patcollins
1687 posts in 2922 days
#14 posted 03-26-2017 03:34 PM
- Carloz
Sounds like you really abuse your counter tops, I never did any of that to laminate or quartz.
