| Forum topic by Josh | posted 980 days ago | 940 views | 0 times favorited | 8 replies | ![]() |
980 days ago |
Topic tags/keywords: question trick joining I tried a couple weeks ago to use some of the thinner stock I had to make a panel that I would use for the bottom of a drawer or for the face on a saw stand cabinet. I ripped the pieces on the TS to make sure they were straight and then used a brush to put glue on the sides, clamped them together and let them chill for a day. When I took the clamps off it looked fine but then I kind of put pressure on the outsides to see how strong it was and it didn’t hold so well. The wood was about 3/8” thick. Does it need to be thicker to glue up a panel and have it hold? Is there some trick I don’t know about? -- Josh, South Jordan Utah |
8 replies so far
#1 posted 980 days ago |
You should be able to easily glue up 3/8” thick material. Make sure you stock is milled perfectly straight and the seam fits with no gaps. Guitar makers glue up much thinner stock all the time with great success. What kind of glue did you use? -- She thought I hung the moon--now she just thinks I did it wrong |
#2 posted 980 days ago |
Titebond original wood glue. The only thing I can think of is that maybe I didn’t mill them perfectly straight. But that’s why I’m asking, just to see if there is a step I’m missing. -- Josh, South Jordan Utah |
#3 posted 980 days ago |
We might be able to give you a better diagnosis if you can clarify what you mean by “pressure on the outsides” and “didn’t hold so well”. -- My broker promised me he would treat my money as if it were his own. Trouble is, he did. |
#4 posted 980 days ago |
A thickness of 3/8” shouldn’t be a problem for a glued up panel. Your edges must be flat and mate together without gaps – this should be checked as a dry fit while applying some clamping pressure. With fresh titebond glue the resulting bond should be strong with even thinner material. Did you get some glue squeeze out when you applied clamping pressure? Tom -- East Side of Big D |
#5 posted 980 days ago |
pressure on the outside would mean I held the panel in my hands and gave it a little bend. The panel was only 10” across but had about 7 pieces glued together to make that 10” didn’t hold so well means that I could visibly see where two of the pieces were coming apart. Like there wasn’t enough glue holding them together but I’m almost sure there was because I can see where I wiped off squeeze out. -- Josh, South Jordan Utah |
#6 posted 980 days ago |
Okay, wood is inherently weak in bending that direction (notice how karate board breakers hold their boards), but it does sound like you had gaps. If it’s only between those 2 pieces, you can rip the panel apart at that seam and glue up the 2 halves again. -- My broker promised me he would treat my money as if it were his own. Trouble is, he did. |
#7 posted 980 days ago |
if glued properly then the glued joint is stronger than the wood itself, has the panel broken exactly where it was glued? |
#8 posted 979 days ago |
Be sure to alternate the growth rings then you should be able to put the 2 or 3 pieces together without any pressure to be sure you have a good straight glue line with no gaps. Then glue your edges and clamp together with enough pressure for a even amount of squeeze out along the joint. Make sure your glue is fresh and not out dated as well. After they dry remove clamps and scrape off excess glue. Thats what I do and have had no problems. -- I don't make mistakes, I have great learning lessons, Greg |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
