Gloss finish on MDF
Forum topic by Eddy2016 posted 02-08-2017 10:28 PM 619 views 0 times favorited 3 replies Add to Favorites Watch
View Eddy2016's profile
Eddy2016
1 post in 671 days
02-08-2017 10:28 PM
Hello,
I am new on this wood world and I am building a floating tv wall, I want to have a piano gloss finish on it. I am Using mdf and I will spray it. What primer, Paint and lacquer should I use to obtain a supper gloss finish?
thanks a lot
3 replies so far
View EugdOT's profile
EugdOT
245 posts in 754 days
#1 posted 02-08-2017 11:29 PM
You will need to seal the edges, with a shellac based primer because the end grain will absorb the paint, you can use a high gloss acrylic paint, to get a good sheen, and you can always put a coat of high gloss lacquer or polyurethane over it.
To get a smoothest coat you need to spray it, if you don’t have access to a hvlp you can use smooth foam rollers and sand in between coats
View Bumpy's profile
Bumpy
40 posts in 680 days
#2 posted 02-08-2017 11:46 PM
I have probably made over a 1,000 MDF raised panel doors and used MDF for case work on built in cabinets for years. The best finish was obtained by using an oil based primer, sand, sand and they spray latex top coat.
Any routed or cut edges may need 2 coats of primer, just be sure to sand smooth.
Good luck-
View SuperCubber's profile
SuperCubber
1042 posts in 2483 days
#3 posted 02-09-2017 01:14 AM
This is the best explanation I’ve seen on the topic:
http://forums.shoryuken.com/discussion/67501/how-to-paint-mdf-to-a-mirror-finish-worklog
He gives lots of detail and plenty of pictures.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
