Grinding Jig Plan Help
Forum topic by Rogue_Bunny posted 02-08-2017 07:00 PM 610 views 0 times favorited 4 replies Add to Favorites Watch
View Rogue_Bunny's profile
Rogue_Bunny
7 posts in 486 days
02-08-2017 07:00 PM
I am building a jig to sharpen my woodturning chisels, and this is the plan I am using:
The thing I am having trouble with is the 2” Long Slot for the coach bolt. How do I do this? I need to make a slot that goes through 3.5” of wood, what tool would I need to use?
View brtech's profile
brtech
1029 posts in 2917 days
#1 posted 02-08-2017 07:03 PM
If I were doing it, I’d split it in half on a band saw, route out the opening, and glue the halves back together.
You can do it with a drill bit – just drill from both sides half way down.
Rogue_Bunny
7 posts in 486 days
#2 posted 02-08-2017 08:54 PM
Thanks brtech, I will give the drill bit idea a try. Not sure if it will end up looking as nice as the picture, but it may serve my purpose.
View Iamjacob's profile
Iamjacob
48 posts in 2620 days
#3 posted 02-10-2017 11:55 PM
I would make the piece out of 4 pieces of wood, a top, bottom, and 2 sides. Glue them up into a block (with the open slot of course) and then shape accordingly.
Rogue_Bunny
7 posts in 486 days
#4 posted 02-11-2017 03:07 AM
Ok…so I tried using the drill bit to make the slot, and I just made a mess of the wood. I finally tried using two pieces of wood, making the slot by passing each half through a table saw, then gluing the pieces together.
Your method would have worked too, Iamjacob.
