gear removal on makita 2030
Forum topic by bos33 posted 02-08-2017 07:00 PM 366 views 0 times favorited 2 replies Add to Favorites Watch
View bos33's profile
bos33
2 posts in 501 days
02-08-2017 07:00 PM
Can anybody describe how to replace both gears under the tray on the makita 2030 planer/jointer
2 replies so far
View Ken 's profile
Ken
20 posts in 1256 days
#1 posted 02-25-2017 01:20 AM
I have a 2030 but I’m not sure which gears you’re talking about. Are these the two gears that raise and lower the table height? And if so, do you just need to try to figure out how to remove them? Or are you looking for replacement gears?
Ken
View MrUnix's profile
MrUnix
6769 posts in 2227 days
#2 posted 02-25-2017 02:35 AM
You talking about these?
If so, you need to remove that bracket held on by 5 bolts so you can access the nut holding the gear on the threaded shaft. Once you remove that gear, the other gear is held in place by a snap ring.
