drying my bog oak
Forum topic by Patrick May posted 09-16-2010 04:20 AM 2453 views 0 times favorited 2 replies Add to Favorites Watch
View Patrick May's profile
Patrick May
24 posts in 2839 days
09-16-2010 04:20 AM
Topic tags/keywords: bog oak kiln drying question oak
Any one out there know much about kiln drying bog oak ?
I just got a log a few weeks ago .I believe it is between 8 and 12 Thousand years old.I will probably have it carbon dated
I had it sawn into boards. Maybe 145 board ft.
I made a small D.H. kiln no heat source ,only the dehumidfier itsellf . I have gotten 4 gallons of water out so far. The wood was over 30%M.C. When I cut it. Now it is at 13%M.C. The temp. of the kiln is slowly rising now it is at 106F.
Do I have to raise the temp? How High? If so how long should I hold it there?Any advise would be appreciated Thanks Pat
2 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3742 days
#1 posted 09-19-2010 12:44 AM
This sounds like an interesting process, do you have any photographs of this?
View Gofor's profile
Gofor
470 posts in 3816 days
#2 posted 09-19-2010 02:48 AM
You may want to see if you can download a copy of this: USDA Agriculture Handbook 188, Dry Kiln Schedules for Commercial Woods,
If you do a search on “Kiln drying schedules for oak”, there is a lot of info available that may let you figure it out using a wet/dry bulb thermometer.
Hope this helps
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
